Revs Out Of Control
Old May 25, 2009 | 12:06 PM
dayton hemi's Avatar
check the map sensor i had similar issues wen mine got plugged
Old May 26, 2009 | 10:21 PM
Cammin Hemi's Avatar
So far I've tried a new t-body, iat sensor, map sensor ( had to grind down a couple tabs on the manifold). No change. It's the tune or maybe the pcm??
Old May 26, 2009 | 11:20 PM
viciousknid's Avatar
Where's the Beef?
I was thinking something like GM's throttle cracker/follower but Mopar is likely a lot different along that aspect. It controls how quick the throttle releases and If it's set too high it will act as a cruise control.
Have you tried Modern Hemi at the top of this forum? Your pt.net login will work there.
Old Jun 6, 2009 | 09:46 AM
spedly's Avatar
sounds like you have a vacuum leak or the tune is way off. Who is tuning it
Old Jun 6, 2009 | 12:19 PM
FrostKing's Avatar
There is nothing there but **** spam.
Old Aug 5, 2009 | 11:21 AM
Mike@Diablosport's Avatar
LS1Tech Sponsor
Sounds like this needs to simply be tuned properly for the cam.
How is it tuned currently, if at all?
We offer full custom tuning for these HEMI Rams, let me know if you need anything.
Old Aug 22, 2009 | 11:38 AM
spedly's Avatar
Hemifever has tuned a few comp 273s. He can fix your airflow issue assuming that you do not have. Mechanical issue. I would contact him he is very knowledgeable and right now an sct tuner is $375 shipped with unlimited custom tuning.
Email him at hemifever@aol.com
Old Sep 24, 2009 | 11:02 AM
LS1Tech Sponsor
How do you do unlimited tuning via email when they have no datalogging support at all?
Logging alone makes the Predator the better option....
Old Sep 24, 2009 | 11:20 AM
00_Hotrod's Avatar
DTC P2173 IN DIAG. INFO SHOWS POSSIBLE LARGE VACUUM LEAK OR PROBLEM W/ TPS..
Old Sep 24, 2009 | 11:25 AM
BlackGMC's Avatar
Resident Retard
Since you had the heads off, i am assuming that you also had the intake off. I would look into a possible vacuum leak as noted by the code above.
