Revs Out Of Control
I was thinking something like GM's throttle cracker/follower but Mopar is likely a lot different along that aspect. It controls how quick the throttle releases and If it's set too high it will act as a cruise control.
Have you tried Modern Hemi at the top of this forum? Your pt.net login will work there.
Sounds like this needs to simply be tuned properly for the cam.
How is it tuned currently, if at all?
We offer full custom tuning for these HEMI Rams, let me know if you need anything.
Hemifever has tuned a few comp 273s. He can fix your airflow issue assuming that you do not have. Mechanical issue. I would contact him he is very knowledgeable and right now an sct tuner is $375 shipped with unlimited custom tuning.
Email him at hemifever@aol.com
Logging alone makes the Predator the better option....
So far I've tried a new t-body, iat sensor, map sensor ( had to grind down a couple tabs on the manifold). No change. It's the tune or maybe the pcm??
