one of you guys should try a megasquirt
Old 07-05-2005, 07:25 PM
Adkoonerstrator
XLR8NSS's Avatar
The megasquirt should work awesome for any platform. One of you guys needs to be a guinea pig.
Do your injectors connectors look like one of the ones in the pic below?
Old 07-05-2005, 07:41 PM
single digit dreamer
parish8's Avatar
i think the mega is especialy good for people without any other tuning options.
Old 07-05-2005, 10:10 PM
11 Second Truck Club
bad360rt's Avatar
Looks like the one on the left, is it rectangular. Stock mine had the newer oval connectors, but I swapped 'em out for the older rectangular ones to run the 36# injectors that I already had.
Old 07-05-2005, 10:14 PM
bad360rt's Avatar
That would be me LOL Well, no affordable options anyway. I'm gonna hold off for a bit, only cause the injectors are gonna cost more than the mega LOL But I think I'll give it a shot.
Old 07-06-2005, 09:58 AM
Five9Dak's Avatar
Do it Dave! My buddy whose into turbos keeps telling me to put my truck on the MS, but its just about stock lol. I want to try it eventually.
Old 07-06-2005, 03:51 PM
bad360rt's Avatar
Is he local? I'd like to find someone local who has experience with it.
Old 07-06-2005, 10:59 PM
Adkoonerstrator
XLR8NSS's Avatar
The injector connector on the left in that pic is a rectangular type. If you have that type they make high-z injectors all the way up to 75# but, I can't find a link at the moment to see what pressure that rating is at.
What sort of fuel pressure do you R/T guys have?
Old 07-06-2005, 11:34 PM
parish8's Avatar
the 60's and 75's and most other injectors are rated at 3 bar, 43psi or whatever it is. i have the 96's wich are more like 108's at the higher fuel presure i am running.
Old 07-06-2005, 11:43 PM
devilbrad's Avatar
Very interesting. Can the MS accomodate nitrous? Like through a WOT switch? And having a large overlap cam is gonna kill my MAP signal, so can it help there too? I was planning on just going with a FAST system, but if this is cheaper and can do it all, I'll step up and try one. I'll just retard the timing with an MSD while on the bottle and all should be fine.
Old 07-07-2005, 10:05 AM
bad360rt's Avatar
I'm running 55psi right now, it gets up to high 60's under full boost (rising rate regulator w/aux pump), stock pressure is around 50psi. I'm thinking some high-z 60's should work nicely.
Quick Reply: one of you guys should try a megasquirt
