edelbrock pro-flo tuning
Old Jul 5, 2008 | 03:27 AM
Default edelbrock pro-flo tuning
alright, my roomie has a 72 gmc pickup with a vortech block, vortech heads, stroked to 383, moderate cam, speed density. a couple issues. one, when he shifts into drive, or reverse, the motor bogs a bit, almost dies. actually, sometimes it does die. it's a TH350, so no electronic controls, and i'm trying to figure out what has to be done to the idle tables, spark advance, fueling, etc, that will avoid this little stumble. other than that it runs pretty well, i'm trying to get him to install a wideband so we can check afr. any ideas, base settings that someone else has used, or something that can help this issue?
Old Jul 13, 2008 | 09:53 PM
Truckshop's Avatar
if you post this in the gm section you may get some more help. in the meantime if you look at moates.net you can get some help along with the software and hardware you need to tune this system.
lsxperformance
Apr 20, 2016 12:17 AM
Sevex
Aug 22, 2015 12:12 AM
steves86ta
Jul 28, 2015 10:21 AM
sauldgold
Jul 23, 2015 02:15 PM
