FS: 02' Sierra RCSB cheap, needs work
Import Moderator
SOLD!!!!
Picture Update
Here are the damage pics on the bed... that is really the only spot on the truck with these big of eye sores. When I had my tonn. cover on it covered pretty much all the damage so you never really could tell.
The engine bay could definitely use a good cleaning as it has been sitting outside for probably close to a month now since I am working on my other truck in the garage
As I said... the truck needs an overall spray down and good wash, if I get a chance too I will clean her up this weekend. btw, the blue mirrors will not be included lol... I will have the factory ones with the chrome mirror caps. and yes the grille and bumpers and all that crap is included
I do have the taillights for this... they will be 99-02, just haven't got around to putting them back on yet from swapping out the 03+s
I do have the door handle piece
Picture Update
Import Moderator
Just to answer a few ?s I received about the truck via PM.
-The truck has everything it needs to run and it will be included in the truck.
-The motor and trans are out of my extended cab Silverado which ran perfectly when I pulled it.
-The body is in great condition aside from a few little spots on the bed rails, when I first got the truck someone had the bed protector bars on it and I didn't notice the 2 holes they drilled in the bed rails. Aside from that, a nice shine job and it will look like it did in the pic above.
-The frame is getting your normal chevy surface rust but is by no means in bad shape, the truck was garage kept for about a year and never driven. The truck still rolls fine so the brakes aren't locked up or anything, but they could def use a good cut (don't think they would need replaced).
-As I stated above, the truck does NOT run. I took the pullout from my Silverado, sat it in the engine bay, put the motor mount bolts in it and called it a day. Its up to you to plug in all the harness and bolt everything else up.
good luck on your sale.
