2007 silverado NNBS, turbo, 4wd
Old Feb 3, 2013 | 04:06 PM
bk_cauley's Avatar
Default 2007 silverado NNBS, turbo, 4wd
Not really enthused about having to do this, but do to a job loss and not being able to afford payments i have to sell. I figured i would try here first before i post it on craigslist.
*will have more pictures posted as soon as possible*
2007 truck with arround 170k. It has a 6 pack cluster in place of the old 4 and it reads 207K i think.
Has a rear mounted 76mm on3 turbo with It has a cx racing intercooler. 50mm sts blow off valve, x02 60mm wastegate. Has a new mocal scavenge pump. Just had it retuned a few weeks ago and it made 410hp 440 ftlb on 6 psi. Had a thread on my screwed up tune, but its since been retuned. he had my timing locked at 10 degrees all the way across the bored and a 10.1:1 AFR. It has a cx racing intercooler.
Engine:
100% stock other than rod bolts.
Transmission:
rebuilt 10k ago with better clutches. have a box of new upgraded hard parts that can go with it.
Fuel:
Flex fuel pump from the NNBS 6.2 trucks and zr1 take out injectors. plenty of fuel for more power.
Tires are 285/55-20 bfg all terrains with about 85% life left.
Has new front and rear brakes.
Has a boost gause and a lc1 wideband mounted in the over head console.
Also have new paint to match handles to go with the truck.
Thats pretty much it. If you have any questions feel free to ask.
Right now i cant do any FULL trades, only partial as i owe money to the bank. $13,500.
If anyone wants to text feel free. My name is keith. im located in thomasville , ga. 31792. my # is 229-413-3306
And yes the exhaust was low in the picture. It fell out of the hanger. its back in now.
Old Feb 4, 2013 | 12:52 PM
bk_cauley's Avatar
If someone wants to offer a 5-6k range truck and payoff i can do that. Payoff it $7200.
Old Apr 7, 2013 | 06:30 PM
bk_cauley's Avatar
Still for sale guys. really need to get it sold before the bank takes it.
Old Apr 7, 2013 | 07:22 PM
mjbaker84's Avatar
post more pictures
Old Apr 7, 2013 | 07:37 PM
bk_cauley's Avatar
I will take some tomorrow. should have them up by 6-630 or so. got a guy local that wants to see it.
Old Apr 7, 2013 | 09:20 PM
mjbaker84's Avatar
sounds good thanks
Old Apr 8, 2013 | 11:12 AM
bk_cauley's Avatar
fyi trans hard parts,
Rear Heavy Duty 5 Pinion Planetary, Front Heavy Duty 5 Pinion Planetary, Gaskets, O-Rings, Lip Seals, Molded Piston,Sealing Rings, 4L60E Corvette 2nd Gear Servo, 4L60E Super Servo 4th Gear Cover, Kolene Steel Kit, Performance Clutch Kit, 4L60E High Performance Band,Teflon Pump Bushing, Delco Front Seal Retainer Clip, Hardened Pump Rings, 4L60E 10 Vane Rotor Gear, 4L60E 10 Vane Rotor Guide, 4L60E 10 Vane High Rev Kit, performance Sun Shell, 29 Element Sprag, Wide Rear Sprag.
and will be home to get pictures in about 2 hours.
Old Apr 8, 2013 | 12:08 PM
RickyMartinZ28's Avatar
In for interior pictures, etc...
Old Apr 8, 2013 | 12:12 PM
bk_cauley's Avatar
Old Apr 8, 2013 | 12:21 PM
Choda's Avatar
Damn this is a horrible situation for u but a good deal for someone looking for a turbo 4x4. Good luck
