2006 trailblazer ss, awd cammed
2006 trailblazer ss. Lt/ss (3ss equivalent for 2006)
Black exterior with black heated leather suede interior.
Power sunroof. Remote start.
All wheel drive.
20% tint
Body and chassis have 127800 miles and going up as it's a daily driver. Engine and front differential were rebuilt at 113k miles. New hankook tires put on at that time.
Engine has king bearings, perfect circle piston rings, pcmofnc rob style cam (220/228-114), brian tooley racing 660 lift dual valve springs with tool steel retainers. Brian tooley racing 7.400 hardened pushrods. XSPower 1-7/8" long tube stainless steel headers. 3" catless y pipe with stock cat back, with pypes race pro muffler in place and resonator deleted.
Stock torque converter redone by winners choice transmissions. Now is a 3000 stall with upgraded clutches from 4l80e torque converter.
Front diff has Yukon gear set, with driveline shop and gm bearings.
Installed within the last 3 weeks. Pass side hub bearing assembly (moog), pass side brake caliper, front brake pads, driver and pass side upper a arm bushings (moog), and new front end alignment.
Within the last year steering wheel position sensor replaced, fuel level sensor and plastic clips replaced.
The following recalls have been taken care of by rentchlers chevrolet : Driver door switch, and headlight driver module.
This truck is very fun to drive. Sounds great. Pulls a car trailer with ease.
It has been as fast as 13.2 @ 102 1.9 60ft full weight with full tank of fuel.
It has a few small blemishes. Small crack in rear bumper on driver side in corner, small crack in front bumper by the scoop on pass side. Pass rear door has a dent from a car door in a parking lot.
$12,500 OBO
Located walnutport pa 18088
(20 min north of Allentown)
The bank does hold the title, but it is easy to retrieve.
No low *****, tire kickers, or time wasters. No joy rides!
Will only consider trade for the following
CASH
2min walk around video
I just picked up a silverado ss do this needs to go.
Thanks
Aaron
All wheel drive.
20% tint
$12,500 OBO
CASH
Thanks
Aaron
ARC
57
02-21-2022 10:54 AM
