2002 SCSB Stepside with LQ4 6.0
Old Apr 27, 2012 | 08:25 PM
erock01chevy's Avatar
Default 2002 SCSB Stepside with LQ4 6.0
I have an 02 scsb stepside silverado for sale. I did the 6.0 swap about a year ago and now I'm moving on cause I have two kids and my wife and I have decided its time for a bigger house.
The Motor!
The motor is a stock bottom end LQ4. When I did the swap I tore it completely down and put new bearings,rings,seals, and gaskets in it. It was in excellent shape but I wanted to do it just because. I put the SLP high volume oil pump in it as well. I wanted it to be a sleeper so I went with the GM performance Z06 cam which is 550/550 with 117.5 lsp. I used my 4.8 heads for higher compression and put the comp LS6 springs on them. The intake is the stock truck intake and throttlebody as well. It also has an K&N cold air intake. Oh yea it has a new water pump and 160 thermostat as well, and the A/C blows cold.
Transmission!
The transmission took some trial and error cause I DID NOT want to go to the power robbing 4L80E. It has the Z pack clutches, wider bands, and the corvette servo. The Magic part was the Raptor Drive Kit that made the tranny stay together and work perfect (three rebuilds later)! I also put a small 2400-2800 stall in it as well.
Rear End!
The rear end has a Duragrip posi unit and 411 gears, with all new bearings and seals. I did the rear end after I had it tuned so the speedo is off and makes the the truck throw a wheel sensor code.
The truck is in really good shape and looks stock, but has one dent under passenger door due to a blow out in the hot Texas heat. I can send you pictures upon request just pm me your #. I'm asking $8500 OBO. I dont have to sell it, but it is time for it to go.
Old Apr 27, 2012 | 08:30 PM
I will make it easy and put my # out there for who ever is interested cause i dont sit in front of the computer very often. (254)498-5725 Just shoot me a text If you are interested.
Old May 1, 2012 | 02:43 PM
Some body make ma an offer! All will be considered!
Old May 1, 2012 | 07:06 PM
Tbss6's Avatar
Clean title? How far from Houston are you ?
Old May 1, 2012 | 07:07 PM
Tbss6's Avatar
This is the white one right ?
Old May 1, 2012 | 08:00 PM
ccantu0389's Avatar
Post Pics
Old May 2, 2012 | 07:49 PM
Yes it is the white one, and I am in waco so a couple of hours. I will try and post some pics in a few min.
Old May 2, 2012 | 09:17 PM
here are some pics!
Attached Thumbnails 2002 SCSB Stepside with LQ4 6.0-imag0096.jpg   2002 SCSB Stepside with LQ4 6.0-imag0097.jpg   2002 SCSB Stepside with LQ4 6.0-imag0108.jpg   2002 SCSB Stepside with LQ4 6.0-imag0100.jpg   2002 SCSB Stepside with LQ4 6.0-imag0111.jpg
Old May 2, 2012 | 09:36 PM
CC05's Avatar
Mileage on frame/rebuild? Willing to do any trades?
Old May 3, 2012 | 10:45 PM
185,103 on the frame, and about 15,000 on the rebuild. This truck was my daily driver up until a couple of weeks ago. The truck is very reliable and solid. And I really can take trades just cash sorry.
