09 turbo silverado 4.8/4l80
Old Jan 20, 2015 | 07:34 PM
Texas5.3_1251's Avatar
Default 09 turbo silverado 4.8/4l80
For sale. $22,000
2009 silverado 1500
4.8 with 4l80
70k
Exterior
Street sence front and rear bumper
Blacked out tail and 3rd brake
Led plate lights
Hids
Limo tint on rear window and 35 on front and 50 on windshield.
22" trailblazer SS wheels
285/45/22 Bridgestone
Tonneau cover
DJM 4/7
Motor
4.8
New short block from a 2010 silverado pulled at 50k
Cam 216/220 561/581 114lsa
Prc .650 dual spring
TSP chromemoly push rods
LS9 head gaskets
ARP head studs
Katech rod bolts
Melling high pressure oil pump
LS2 timing chain
LS7 lifters
LS9 injectors
Snow performance meth kit
Tuned for 93
Kb racing turbo
76mm magnum
Intercooler
Jgs wastegate
Jgs blow off valve
Turbo blanket
AEM true boost gauge
AEM A/F gauge
Aeromotive 340lph
Trans and rear end
4l80
Billet rollerized forward clutch hub
36 element sprag steel direct drum
Sonnax boost valve
Sonnax AFL valve
Modified 3rd gear clutch circuit
6 clutches in direct drum
FLT calibrated valve body & pump
Bushing kit
Bearing kit
OD roller clutch
Low roller clutch
Low/Reverse & manual 2nd bands
All solenoids
Manifold pressure switch
Internal wire harness
Filter
Spacer plate
New speed sensors
Trans go shift kit
3400 stall
Trans cooler
Steel two piece driveshaft
3:73 gears
Tru trac
Interior
All speakers are DD composition
Hertz tweeters in kick panels
1,000 watt DD amp for mids and highs
1,000 watt DD amp for sub
18" DD 2500 series subwoofer
Custom fiberglass box.
Clifford remote start and alarm
Located in
Simpsonville, South Carolina
Old Jan 26, 2015 | 06:48 AM
00T/AWS6's Avatar
RWD, 4WD? Any numbers or estimate on power? Bump for clean truck
Old Jan 29, 2015 | 04:39 PM
Interested. Is it 4wd? Are there more pictures available?
Old Jan 30, 2015 | 10:54 PM
Denali734's Avatar
Default clean Shiny Truck
whp ? more pic dud...
Old Feb 4, 2015 | 09:08 PM
2wd and no hp numbers.
Old Feb 11, 2015 | 08:34 AM
reeperz28's Avatar
Pm me if still for sale. Would like to talk about the truck some more. You can text me at 806-382-3553
Old May 17, 2015 | 08:41 PM
Default New price!
$22,000
Rafe19
Oct 18, 2016 12:27 AM
5.3lSilverado
25
Aug 29, 2016 12:48 AM
Raggedz71
Jul 29, 2016 10:20 AM
chopperloco
Jul 10, 2016 10:45 PM
Deceptarado
Jul 8, 2015 05:24 PM
