08 Built TBSS Granite AWD - $18500
Old 06-21-2016, 11:22 AM
8 Second Club
MIGHTYMOUSE's Avatar
Default 08 Built TBSS Granite AWD - $18500
SOLD
VIN - 1GNET13H782198152 - it is a 3SS no nav/dvd
more photos https://picasaweb.google.com/1144453...197820/08TBSS#
photos lowest in the gallery were taken this morning (after rain, so what you see is RAW not washed or detailed to trick you) I have the engine cover just not installed currently.
Huron XS off road longtubes
MM Gen4 PCV catch can
MM E-fans (computer patched)
new headlights
new front swaybar links
replaced front driveshaft
replaced transfer case rear main seal
new drilled and slotted rotors and pads / powdercoated front calipers, painted rear
AEM a/f gauge
monoblade wipers
Thompson Motorsports LS2 Aluminum Short block (10k miles est)
I was told this build includes the oil pan mod kit
Rob Style Cam
Brian Tooley Pushrods
LS7 Lifters
Melling high pressure oil pump
replaced timing gear and chain
ARP Head Bolts
NGK Spark Plugs
CAI 4" Intake
180 T stat
recent battery replace
billet front grill emblem
Transmission is Performance Built Level one from ShiftRite in Illinois (10k miles est)
2000 Stall
Powdercoated flat black wheels (very flat)
Hankook rh07 275/45/20
1" Spacers all around
20% tint
magnaflow muffler and a Dougs Electric cutout
remote start
lowered slightly
current mileage = 103.1k
the engine and trans run like a top, and in general drives great, ride is just fine, everything works inside.
tune could use a clean up, does slight lean surge at warm idle randomly (most people think it sounds sweet like this, does not bother me)
the body has marginal work done on the passenger rear door, sanding visible through the paint. most can't to see it.
the driver rear door has a shallow 8" crease
only other thing i can think of is the driver front tire has a slow leak at the TPMS seal, i have a new kit for all 4 but not yet installed. tires in good shape, tpms sensors work fine.
It has burned through 2 msd wires since header install so you will see a couple stock wires in the mix
hopefully you see that I am a full disclosure seller; often great deals are not, but from me you are getting what you think you are.
title in hand, available for test drive and pickup in 23060 VA.
Old 06-27-2016, 08:12 AM
8 Second Club
still available
Old 07-06-2016, 08:33 AM
8 Second Club
still here
Old 09-26-2016, 08:26 AM
8 Second Club
this is back up available
Old 01-18-2017, 04:08 PM
8 Second Club
its sold
About20ninj45
11-01-2021 12:51 PM
Txyote
02-20-2016 02:41 PM
cj847
02-20-2016 02:13 PM
really slow truck
01-27-2002 09:04 AM
DV8
01-16-2002 12:44 AM
Quick Reply: 08 Built TBSS Granite AWD - $18500
