80e and Borg Warner Transfer case...anyone done it?
Looking to go 4l80 with awd. I dont know if i have a BW or an Nvg 149.
anyone have information on using the BW for this application?
I did it with my truck that has a BW 4481. Your going to need a different adapter and either change the 4L80e output shaft to 27 spline or change the input shaft on the TCase to 32 spline. I went with upgrading the 4481 BW transfer case with parts from a newer BW, i think 4482 that sit behind a 6L80e. They have the 32 spline input shaft along with a sprocket and chain that are a 1/4" thicker. I went with the shaft, bigger sprockets and chain to make it as strong as i can.
Hope this helps.
Hope this helps.
The BW4482 requires electric shifting unless you lock it into AWDhi and leave it. Would need a cover plate for the shifter hole. If it ever popped out of gear going down the road you would be screwed though.
I am not sure how much effort it is to add electric shifting to an AWD vehicle. You would need the shift motor and the button and harness.
I just went back and looked, it was the BW 4485 that were in 2007 - 2011 Escalade's.
And these are the parts I ordered to do it.
GM Part # Description
19132803 SHAFT,TRFER CASE INPUT
19167564 Sprocket
19151772 Chain
88984540 Sprocket
88984518 Washer
15654927 Adapter
19167564 Sprocket
19151772 Chain
88984540 Sprocket
88984518 Washer
15654927 Adapter
19167564 Sprocket
19151772 Chain
88984540 Sprocket
88984518 Washer
15654927 Adapter
19167564 Sprocket
19151772 Chain
88984540 Sprocket
88984518 Washer
15654927 Adapter
If I'm not mistaken, the 4481 isn't chain driven like the nvg149 is
