Whats your solution???
Old Feb 13, 2008 | 08:01 PM
03sierraslt's Avatar
Default Whats your solution???
You have a building with 3 above ground floors, and a basement. 4 Floors total. On the 3 above ground floors there is one lightbulb on each floor, total 3 lightbulbs. You are in the basement, in the basement there are 3 light switches that control the 3 light bulbs. None of the light switches are marked for what floor. (each switch controls a light on each floor in no order) You cannot see anything on any of the above floors at all and have no help. You can go up the stairs to any floor and return to the basement only once. How do you determine which switch controls which floor.
Hopefully I didnt leave anything out... Its not a trick question.
Old Feb 13, 2008 | 08:30 PM
duwem's Avatar
Turn on the 1st or 2nd switch or the 2nd or 3rd switch, then check all 3 floors, either the 1st floor or 3rd floor wont be lit.
Old Feb 13, 2008 | 08:37 PM
Moddoo's Avatar
dewem you only figured out 1 switch.
It's a good riddle.
I don't want to spoil it.
Old Feb 13, 2008 | 08:39 PM
Nope, that still wont tell you what switch controls what floor for all 3.
It's a good riddle.
PM me if you know the answer, I dont want to post it yet.
Old Feb 13, 2008 | 08:41 PM
There is a simple way to do it, most people think it something complicated but its not.
Old Feb 13, 2008 | 08:49 PM
duwem's Avatar
I was thinking the switches were in a row 1-3...gota read better!
Old Feb 13, 2008 | 08:53 PM
Nope no order to the switches. Moddoo got it.
Old Feb 13, 2008 | 09:03 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
easy....
go to the first floor, hit the switch.....go to third floor and flip that one....go to basement...call an electrician and wait for help
Old Feb 13, 2008 | 09:18 PM
99Silverado5.3's Avatar
Turn one switch on (any floor)
Leave one off (any floor)
And on the third put a lot of extra voltage to it the bulb can't handle
then just determine which one isn't burned out and that's your three.
