What should I do with the Hoe? Part it/sell it?
Old Apr 9, 2013 | 10:15 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Took Bill a year or so to sell his for a decent price so theres a chance but probably easier to part out.
Old Apr 9, 2013 | 11:17 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
If you don't have all of the parts to return it to stock, you could always just part everything out, and then sell the roller to Cody.
Old Apr 14, 2013 | 03:38 AM
1SlowHoe's Avatar
Destroyer of Transmissions
Lol, does Cody need a roller Tahoe? How many kids di he have while I wasn'tlooking?
OK, I think you guys are right and I was pretty sure that was going to bethe answer. I've already had 2 people ask about the 80E and I haven't evenopened my tool box
So here is the part I rally need help with, what's this stuff worth? I'm notexpecting top dollar for everything, in fact I think I can be pretty reasonablebecause I don't need the money for anything particular at the same time I don'tNEED the money so I will let it sit in the garage for low ball offers.
The 408 has MAYBE 1,800 miles on it. I bought it from Three6GMC in CorpusChristi, TX. He said it had 800 miles on at and I believe him because it wasvery clean.10.4:1CR with the current heads//Brand new GM 6.0 block-Arias (-3cc) forged pistons-Total seal piston rings--Eagle forgedH beam rods-Eagle 4.0 forged crank with 58x reluctor wheel-Clevite H mainbearings-Clevite G rod bearings-All ARP bolts-truck oil pan -new front and rearcovers-ls7 cam sprocket-ls2 chain-ls2 lifter trays-ls7 lifters-high volumeMelling oil pump-cam spec'e by PatG for the blower. 231/239 .598 .610 116 /LS9head gaskets, ARP head bolts, ARP crank bolt, IW balancer
Price on Short block/LongBlock (See heads below) $X,XXX ??
Heads are from Richard at WCCH. They are LSA heads(LS9/ZR1) flow 350CFM at.600/ 75cc chambers w/Patriot Extreme Gold springs/Stage2 CNC /1,000 miles $X,XXX ??
PI triple disc 2600 rpm converter $XXX
Built 4l80E $XXX ??
TVS2300 front drive/ 1,000 miles (brand new when Igot it) $X,XXX ??
8-rib set up/PS pump/Alt/2 Idlers $XXX ??
3.5” OD Aluminum driveshaft balanced to somethingridiculous/1350 U-joint (Can it be cut to fit another application? $XXX ??
Lingenfelter 24x to 58x conversion box $XXX ??
Most of the other stuff will just stay on the Tahoefor sale, so guesstimate I spend $1,000 on a 5.3/4L60 and a new cross member.What's the truck worth based on the pictures. Still has an Eaton and 4.10gears. $X,XXX??
Fill in the XXXX and let me get started!
Old Apr 14, 2013 | 04:02 AM
rjwz28's Avatar
Man Motor club
Heads $600, sell them to me!!!
Good luck with the part-out man, hope it all goes as planned and you don't have any problem getting everything sold.
Old Apr 18, 2013 | 11:49 AM
1SlowHoe's Avatar
Bump for some numbers. I'm going to part it out starting this weekend. I'd like to get things listed asap. Anybody got suggestions on prices?
Old Apr 19, 2013 | 11:46 AM
holley2346's Avatar
I see this two weeks after ordering a LME 408 with LSA heads and a similar cam for my tahoe......
I am interested in your supercharger and 8 rib kit, PM me when you figure out a price.
Old Apr 19, 2013 | 02:44 PM
travieso's Avatar
Nice truck you're basically building what i've always dreamed off. Did you ever run at the track with this set up?
5.3Caprice
Nov 7, 2015 08:56 PM
Three6GMC
Oct 27, 2015 08:04 PM
vmaxpro
Aug 25, 2015 06:35 PM
Fast86z
Aug 23, 2015 12:35 AM
