What should I do with the Hoe? Part it/sell it?
Destroyer of Transmissions
Lol, does Cody need a roller Tahoe? How many kids di he have while I wasn'tlooking?
OK, I think you guys are right and I was pretty sure that was going to bethe answer. I've already had 2 people ask about the 80E and I haven't evenopened my tool box
So here is the part I rally need help with, what's this stuff worth? I'm notexpecting top dollar for everything, in fact I think I can be pretty reasonablebecause I don't need the money for anything particular at the same time I don'tNEED the money so I will let it sit in the garage for low ball offers.
The 408 has MAYBE 1,800 miles on it. I bought it from Three6GMC in CorpusChristi, TX. He said it had 800 miles on at and I believe him because it wasvery clean.10.4:1CR with the current heads//Brand new GM 6.0 block-Arias (-3cc) forged pistons-Total seal piston rings--Eagle forgedH beam rods-Eagle 4.0 forged crank with 58x reluctor wheel-Clevite H mainbearings-Clevite G rod bearings-All ARP bolts-truck oil pan -new front and rearcovers-ls7 cam sprocket-ls2 chain-ls2 lifter trays-ls7 lifters-high volumeMelling oil pump-cam spec'e by PatG for the blower. 231/239 .598 .610 116 /LS9head gaskets, ARP head bolts, ARP crank bolt, IW balancer
Price on Short block/LongBlock (See heads below) $X,XXX ??
Heads are from Richard at WCCH. They are LSA heads(LS9/ZR1) flow 350CFM at.600/ 75cc chambers w/Patriot Extreme Gold springs/Stage2 CNC /1,000 miles $X,XXX ??
PI triple disc 2600 rpm converter $XXX
Built 4l80E $XXX ??
TVS2300 front drive/ 1,000 miles (brand new when Igot it) $X,XXX ??
8-rib set up/PS pump/Alt/2 Idlers $XXX ??
3.5” OD Aluminum driveshaft balanced to somethingridiculous/1350 U-joint (Can it be cut to fit another application? $XXX ??
Lingenfelter 24x to 58x conversion box $XXX ??
Most of the other stuff will just stay on the Tahoefor sale, so guesstimate I spend $1,000 on a 5.3/4L60 and a new cross member.What's the truck worth based on the pictures. Still has an Eaton and 4.10gears. $X,XXX??
Fill in the XXXX and let me get started!
5.3Caprice
Nov 7, 2015 08:56 PM
Fast86z
Aug 23, 2015 12:35 AM
