using belt to lock crank for crank bolt removal
Old 08-23-2012, 02:46 PM
  #21
Mod with training wheels
smokeshow's Avatar
I was helping a friend pull a crank pulley off a BMW in the car last year and his 1200ft-lb impact with oversized air hoses wouldn't pull it off. Tried cranking it over with a breaker bar against the frame to use the starter to break the bolt loose....nothing. Showed him the belt trick...between two of us pulling on a 5 foot breaker bar, that bitch came off.
Old 08-23-2012, 02:58 PM
  #22
Tin Foil Hat Wearin' Fool
1slow01Z71's Avatar
I'm a big ***** when it comes to putting that much force on a breaker bar. I'm always afraid its going to slip off the bolt and make me rip my taint.
Old 08-23-2012, 03:23 PM
  #23
TXsilverado's Avatar
lol, that's my torque spec on crank bolts. to hell with all of that degree crap. i seat it with the crank pulley tool, tighten it as tight as i can with an impact then put a breaker bar on with the longest cheater i can find and dont stop torquing until my taint rips.
Old 08-23-2012, 04:02 PM
  #24
LS1TRUCKGUY's Avatar
roflmao!
Old 08-23-2012, 06:30 PM
  #25
06murder's Avatar
You could put the starter back on an get some good vice grips and turn motor overto the vises on on the srarter then try busting crack off
Old 09-02-2012, 04:20 PM
  #26
Jetn3's Avatar
I have used a chain through crank pulley and around the frame with a nut and bolt to remove and torque crank bolt.
Old 09-02-2012, 04:30 PM
  #27
Gadgetized's Avatar
I have used the belt trick and it works real well. (Actually learned it from this site ) I usually use an impact though. Once I had my bolt loosen up even with threadlocker.
Old 09-02-2012, 05:30 PM
  #28
fastnblu's Avatar
anyone got a picture of this? i'm trying to explain how to do it on another forum to help a guy but a picture would help alot.
What are u doin on another site?!?
I say just for that, then this...
Get a bigger impact.
Even on an engine stand, shouldn't a powerful enuff impact get it loose?!?
It's how it did cause it was on the truck. I know u said stand.
But 1 of these days I might need to build a "more" stout LS motor.
As I know of the belt trick, it's in my mental arsenal if I need it. Hopefully when I do a motor, it'll be in car so I can break crank bolt loose, then pull motor.
Originally Posted by smokeshow
I was helping a friend pull a crank pulley off a BMW in the car last year and his 1200ft-lb impact with oversized air hoses wouldn't pull it off. Tried cranking it over with a breaker bar against the frame to use the starter to break the bolt loose....nothing. Showed him the belt trick...between two of us pulling on a 5 foot breaker bar, ... came off.
Yet another reason not to buy a BMW. :
We need a no import smilie. Heck, maybe a non-GM smilie.
1200 ft lbs.?!?
Then it wasn't that day Jake.
5.3Okasai
03-09-2022 01:07 PM
Corvette454l88
09-01-2016 01:24 AM
signguy62
07-16-2015 05:43 PM
GreyChevy
07-07-2015 08:57 PM
Quick Reply: using belt to lock crank for crank bolt removal
