using belt to lock crank for crank bolt removal
#21
Mod with training wheels
I was helping a friend pull a crank pulley off a BMW in the car last year and his 1200ft-lb impact with oversized air hoses wouldn't pull it off. Tried cranking it over with a breaker bar against the frame to use the starter to break the bolt loose....nothing. Showed him the belt trick...between two of us pulling on a 5 foot breaker bar, that bitch came off.
#23
lol, that's my torque spec on crank bolts. to hell with all of that degree crap. i seat it with the crank pulley tool, tighten it as tight as i can with an impact then put a breaker bar on with the longest cheater i can find and dont stop torquing until my taint rips.
#24
#28
I say just for that, then this...
Even on an engine stand, shouldn't a powerful enuff impact get it loose?!?
It's how it did cause it was on the truck. I know u said stand.
But 1 of these days I might need to build a "more" stout LS motor.
As I know of the belt trick, it's in my mental arsenal if I need it. Hopefully when I do a motor, it'll be in car so I can break crank bolt loose, then pull motor.
I was helping a friend pull a crank pulley off a BMW in the car last year and his 1200ft-lb impact with oversized air hoses wouldn't pull it off. Tried cranking it over with a breaker bar against the frame to use the starter to break the bolt loose....nothing. Showed him the belt trick...between two of us pulling on a 5 foot breaker bar, ... came off.
We need a no import smilie. Heck, maybe a non-GM smilie.
1200 ft lbs.?!?
Then it wasn't that day Jake.
Corvette454l88
09-01-2016 01:24 AM
GreyChevy
07-07-2015 08:57 PM
