using belt to lock crank for crank bolt removal
Old 08-23-2012, 11:26 AM
11 sec. Truck Mod
TIM Z's Avatar
I've always used a prybar as a holdback.
Old 08-23-2012, 11:50 AM
Baltimore Whore
Mangled03gmc's Avatar
Originally Posted by Atomic
This...
BINGO, make sure they are holding the stand
Old 08-23-2012, 12:33 PM
Camaro Zach's Avatar
2j not an ls motor but same concept:
Old 08-23-2012, 12:43 PM
11 Second Club
Phantom's Avatar
Tyler (dirt_track_racer_81 did it on my motor a few years back
Old 08-23-2012, 12:49 PM
11 Second Club
Phantom's Avatar
Old 08-23-2012, 01:01 PM
TXsilverado's Avatar
bingo. thanks guys. this trick has always worked great for me. i'm always working alone so the screwdriver in the flex plate is a pita and i never have someone around to hold the back of the engine. the belt trick is easy and works when i dont have 2 extra hands.
Old 08-23-2012, 01:04 PM
GMCtrk's Avatar
It worked great for me too. Dirt track racer was the first to post this concept several years ago
Old 08-23-2012, 01:26 PM
I have a gauge for that
Atomic's Avatar
I usually shove a breaker bar in the side of the crank pulley and wedge it against the frame...
Old 08-23-2012, 01:37 PM
that works great for removal, but not so good for putting it back on if i remember correctly. also, aftermarket underdrive pullies are solid so you can't stuff a breaker bar through it. 3rd if the motor is on a stand, there is no frame below to wedge into. and finally this would be on an s10 application so i dont know what the frame looks like down there...there may not be anything to wedge on a LS swapped s10.
Old 08-23-2012, 02:38 PM
TX Tahoe Z71's Avatar
I used a vice grip tightened down really good on the flex plate and an impact.
Quick Reply: using belt to lock crank for crank bolt removal
