It is that time again - Resident Retard Stories
Resident Retard
1. Welding in flip flops is bad on so my levels.
2. Resist the urge to scratch your nose when your hands are covered in grease and smelly read end fluid. The smell never goes away.
3. Windex is not a good hand cleaner and it feels awesome on cuts!
Stay tuned for more.
Resident Retard
More to add from yesterday.
When installing new gears.
1. Make a setup bearing for the front pinion bearing, not just the rear.
2. By all means install gears in your garage, on jack stands in 100*+ weather, you will enjoy it.
When removing oil pans and trans pans, be sure that your face is directly underneath them and that your mouth is open when you remove that last bolt. I recommend this especially on trans pans, as Dexron tastes better than used motor oil.
