A-pillar gauges
Old Oct 15, 2008 | 03:28 PM
SierraSS22's Avatar
Registered User
Default A-pillar gauges
Why would someone put Water temp. or oil pressure or oil temp. in the a-pillar? What are they used for? Pros and cons?
Old Oct 15, 2008 | 04:11 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
I moved this to the 'truck stop' for lack of a better forum to place it in.
To answer your question it would be for that go-fast look as there is a water temp (although inacurate) and oil pressure stock in a few clusters and a simple cluster swap will provide that if it isn't stock for your vehicle.
Any gages on an A-pillar shoul be be to monitor Nitrous/Turbo/Supercharger function. Not that oil pressure and water temp aren't important, just that putting them on a pillar pod is kinda _____...you can fill in the blank.
Old Oct 15, 2008 | 04:35 PM
Mangled03gmc's Avatar
Baltimore Whore
O0o O0o I would like to solve GAY___
What Trev said, you would really want to put AFR Boost, Fuel or nitrous pressure there..
John
Old Nov 4, 2008 | 06:48 PM
ChevyMan23's Avatar
I have an Interceptor guage that I need to mount, and I was wanting to mount 2 guages instead of just one(only cuz I think 1 looks silly, lol). I am not running gas, and Im not boosted. I was looking at Oil temp as an option, any other ideas? If the oil temp is an ok idea, whats the best route to hook it up on these trucks? Iv seen a thread simliar to this before, but cant find it.
Old Nov 4, 2008 | 07:37 PM
skeet's Avatar
i agree with the above but i run 2 guages for NA setup, fuel pressure, and AFR!! went with fuel pressure so i can see it at WOT, and AFR for the tune..
Old Nov 4, 2008 | 07:41 PM
trever1t's Avatar
Wideband....not narrowband (just for clarity)
Old Nov 4, 2008 | 07:43 PM
skeet's Avatar
thank you sir!! i knew i could count on ya for clarity lol jfwy
Old Nov 4, 2008 | 08:57 PM
ZQ8Dude's Avatar
Plus on a new vehicle a scangauge will pretty much replace the entire cluster.
Old Nov 6, 2008 | 08:16 PM
ChevyMan23's Avatar
anyone?
Old Nov 6, 2008 | 08:51 PM
viciousknid's Avatar
Where's the Beef?
I think your asking where you can mount one or two... am I right?
If so look at this thread i started asking basically the same thing. Couple suggestions in there you may like.
https://www.performancetrucks.net/fo...ht=gauge+mount
