Ok guys, someNEWB ???
Old Oct 30, 2008 | 11:34 PM
Mangled03gmc's Avatar
Baltimore Whore
Damn good info, but I already have the shortys on. SO should I take them off and go back to stock?? The 2 tornaders make sense, will have to pick them up..
John
Old Oct 30, 2008 | 11:36 PM
built408's Avatar
Sweet they are at the and more at sometimes, this thing must really be running good, the smoke, I kinda thought that. but when I was wide open the other night, it sounded like alot of change or metal rattiling around??? What could that be, something loose. I though it could be detonation, but my tuner assured me it was fine???
John
I use to have this same problem, I lowered my fuel pressure and it went away, weird.
Baltimore Whore
Originally Posted by RandomHero
I'd recommend a port and polished MAF sensor so increase flow. People don't realize this, but there is a lot to be gained from weight reduction. I drive a lowered truck and I realized my c-notches on the rear part of my frame were weighing me down so i removed them.
Also, I removed my A/C in regards to weight reduction. To get some air flow in there I routed my tailpipe into the cab so I can get a bit of circulation.
Excellent point, but i would have to ride wit the windows down, esp since I have all that smoke coming out my tail pipes.. ?? Better yet, link me to a place with good gas masks, then it will look like I am in a race truck
John
Old Oct 30, 2008 | 11:38 PM
dirt track racer 81's Avatar
here you go direct exhaust injection..its new and still in the works maybe you can be the guinea pig http://forums.thedailywtf.com/forums/p/7357/137424.aspx
Old Oct 30, 2008 | 11:40 PM
built408's Avatar
No, don't remove the a/c. Just route all the ducts to the throttle body and turn it on full blast. This is a supercharger and an intercooler all in one unit. Then just get a turbo whistler and put it on you tailpipe so it sounds like a turbo.
Old Oct 30, 2008 | 11:43 PM
then get a nitrogen tank and run a line from that to your intake then you got nitro, supercharger, intercooler and then a turbo effect
Old Oct 30, 2008 | 11:44 PM
A Low Dime's Avatar
13 Second Truck Club
Make sure you add lots of timing, thats where the power is.
Old Oct 30, 2008 | 11:45 PM
40,50,60,80??
Old Oct 30, 2008 | 11:47 PM
built408's Avatar
Well if your going to run nitro, just make sure you get a 5 inch monster tach and put it on the dash so you can't see in front of you. Because your factory tach isn't compatible with nitro. Everybody knows that.
Old Oct 30, 2008 | 11:48 PM
Baltimore Whore
Good good keep it coming, I like the charger and ic all in one, the whistly tips are neat, but I duno, think they will help power, they sound mean.. Yah my tuner says the same thing on timing, so I am like keep adding it in there iggie, thas his name.. knows his **** thowe. Also really nice guy, does what ever I tell him to do as far as tuning
John
