Ohh man lookie at what Mr brown dropped of today.
Old May 1, 2008 | 08:27 PM
Mangled03gmc's Avatar
Baltimore Whore
Default Ohh man lookie at what Mr brown dropped of today.
I can't wait to get these in the truck, it has been a long, well deserved wait for me....
John
Old May 1, 2008 | 08:31 PM
pj4553's Avatar
Nice. Do share details!
Old May 1, 2008 | 08:38 PM
Onyx 02's Avatar
3200 and Performabuilt? What size cam you running?
Old May 1, 2008 | 08:41 PM
Baltimore Whore
You got it
A comp(TSP) 224R 581 on a 112lsa
John
Old May 1, 2008 | 08:45 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
nice!
Old May 1, 2008 | 08:50 PM
Silver-Dollar's Avatar
You will like the combo (see sig). I watch them remove and replace the bellhousing when the swap was done. One bolt was not coming out. They ended up taking an air chisel to knock the head off. Also, there was a slight issue with my tranny. You may want to check before you begin the install the length of the shaft where the neutral safety switch is mounted on. Mine had a car shaft when built and needed to be replaced before it could go back in. Fortunately there was a spare and the were able to swap it out (which involves opening up the transmission).
Old May 1, 2008 | 09:16 PM
Baltimore Whore
[QUOTE=Silver-Dollar;3910790]You will like the combo (see sig). You may want to check before you begin the install the length of the shaft where the neutral safety switch is mounted on. Mine had a car shaft when built and needed to be replaced before it could go back in.
I hope not, I will take a look b4 it goes in, thanks on the heads up..
John
Old May 1, 2008 | 09:35 PM
fastnblu's Avatar
John, that's really cool brother. That tranny came UPS? or freight? I sent u a PM. Let's see some vid of truck after it's installed, this kind--->
Old May 1, 2008 | 09:37 PM
bluecajun5.3's Avatar
11 Second Truck Club
when you swap the bellhousing, make sure to heat up the torx bolts with a torch or you'll be breaking torx bits if they are off the shelf ones.
Old May 1, 2008 | 10:07 PM
Baltimore Whore
Will do thanks bra
Also it came UPS ground, it only weight 130 lbs.
John
