Need help and info to run lo 12's f/i
Old Jan 8, 2009 | 02:57 PM
chevrolade's Avatar
Exclamation Need help and info to run lo 12's f/i
Well guys here are my mods
2008 4.8 rated at 295hp
112 radix@6psi
edelbrock shorty headers
cats deleted
3 inch dynatech muffler
ported tb
k-n cold air box
ls6 zo6 cam w/springs
vette servo
factory 3.23's one tire fire
np tune(mail tune)
now mods on the way....
90mm j-tube
4.10 tru-trac
thats my goal guys to run low 12's with this little 4.8 /later it will get pulled for a 6.0 and then it should have no problem .
Old Jan 8, 2009 | 04:56 PM
03sierraslt's Avatar
Sooooo what does it run now?
Old Jan 8, 2009 | 06:54 PM
chevrolade's Avatar
Well i ran it magnacharger at 5psi,exhaust only,cats deleted
hit a 15.3@103 spinning one tire bad on 3.23s
Old Jan 8, 2009 | 07:12 PM
BlackGMC's Avatar
Resident Retard
what about some long tubes?
Old Jan 8, 2009 | 07:34 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
I'm sorry but thats horrible. Stock you should be right around that...
The true track and gearing is going to make a big difference. Get some slicks and heat them up. The speed was good for a high 12 sec run. You don't need to mod a bunch, you need to get the power down to the ground!
Old Jan 8, 2009 | 08:51 PM
No wind resistance on a dyno
Old Jan 8, 2009 | 08:57 PM
chevrolade's Avatar
I was thinking longtubes as well.i hope the4.10's help,i know that tru trac willANYTHING ELSE?
Old Jan 8, 2009 | 10:36 PM
PappyDan's Avatar
Tribe Shaman
something is not right.
Old Jan 8, 2009 | 10:40 PM
ces63ss's Avatar
that right there should get you pretty close and if not the 150hp shot of N2O should. You could always just add a nice blown 408 and juice
Old Jan 9, 2009 | 09:33 AM
sickREDsierra's Avatar
if the true trac doesnt do it, i would get a nice stall. the 4.8's just dont make torquw down low.. a good 2600+ stall and true trac with DR's will def do what you want.
probably mid-low 12's actually
