leave it in drive or shift up from 1
Old May 24, 2006 | 12:49 AM
adrenalinep's Avatar
Default leave it in drive or shift up from 1
just curious on how most of yall take off in a race. Is it better from 1st or from drive at track or street from a stop. I usually go from 1st,
Old May 24, 2006 | 01:07 AM
TouchOfEvil04's Avatar
Not sure which is better..or if theres even a differance.However, i simply leave it in D and give it the gas.
Old May 24, 2006 | 08:26 AM
Nick™'s Avatar
get your tune set right and leave it in drive - you'll be more consistant and the computer is better at shifting "where you want it to" than you are. the only reason to shift it yourself is if you want to try different shift points, but after you know what you want at WOT adjust it in the tune and let the truck do it
Old May 24, 2006 | 08:35 AM
chapita's Avatar
i leave it in three
Old May 24, 2006 | 08:41 AM
TXsilverado's Avatar
i hold second a little longer but thats just cuz i forgot to tell my tuner to bump up the 2nd rpm shift. just put it into 3 and let it rip.
Old May 24, 2006 | 11:41 AM
white1's Avatar
I put 'er in 3
Old May 24, 2006 | 09:16 PM
OUT2WIN's Avatar
I have never ran it shifting myself, so I leave it in D. Is 3 better than Drive?
Old May 24, 2006 | 09:47 PM
3 just prevents it from goin in overdrive, and at wot u wont go into overdrive anyway unless tuned to do so. to shift into forth at wot on a stock tune its like over 200mph before it does so (so its impossible)
Old May 24, 2006 | 10:49 PM
thanks for replies , I going to leave it in 3 from now on
Old May 25, 2006 | 12:28 AM
F8L Z71's Avatar
I leave it in 3rd. Keeping it in drive often makes you shift into OD when you lift at the end of the 1/4mile. Being in 3rd gear helps to slow the truck down better than being in 4th.
