installing a cam questions
Old Jan 7, 2009 | 12:54 AM
02gmcbandit's Avatar
Default installing a cam questions
ok im not about to do it, i'm waiting on my income tax money till i make up my mind on my next mod, BUT if i was to install a cam is there anything that can go wrong? timing issues? ect. is there a specific way to install a cam? also how the heck do you change springs with the heads still on the motor? or would i need to take the heads off and change springs and push rods???
Old Jan 7, 2009 | 01:03 AM
vff_jeff's Avatar
to change the springs youl need an air fitting that screws into the spark plug hole. with your compressor it will hold the valves up. Other method is to rotate the crank until the piston is at TDC. but you have to do this with every cylinder. As for problems and tips... Get someone who has done it before to help you. Its not hard, just time consuming. I bought 5/16 wood dowel rods from home depot to hold the lifters up while I swapped out the cam. make sure the cam is degreed right. don't drop a valve lock. buy hardened 7.4 push rods. And you will need a tune for sure.
Old Jan 7, 2009 | 01:08 AM
JakeBrakeIH's Avatar
http://ls1howto.com/index.php?article=23
read over than, i used that for when i did my cam, buy extra keepers cuz more than likely u will lose one...there are a few different valve spring compressors out there just personal preference and budget...
The_W
Oct 28, 2015 09:00 PM
all_individual
Oct 10, 2015 10:09 PM
WICK3DxGATA
Jul 21, 2015 06:59 PM
FlowmasterMufflers
Jul 17, 2015 03:26 PM
all_individual
Jul 13, 2015 11:01 AM
