Home electrical-how to: New wiring on patio-2,3-way dimmer switches? how's it done?
Old Feb 14, 2010 | 07:50 PM
Tootall's Avatar
Default Home electrical-how to: New wiring on patio-2,3-way dimmer switches? how's it done?
I'm trying to wire up the lights on my patio. I have to run all the wires before I seal up the celing.
I have 8, 50w ceiling mounted lights.
I want to have a dimmer switch outside, and another inside. The 2 switches that I have are 3way dimmer switches.
I wired the 8 lights with 14g 2wire with ground
A new circuit is being pulled from the breaker box.
Do I need to run the new source wire to one switch,
From each of the dimmer switches - a 3 wire to the loop that I made to the ring of the 8 lights?
What am I missing or what's needed?
Old Feb 14, 2010 | 08:22 PM
454navyss's Avatar
are you using one switch for all 8 lights?
its hard for me to try to visualize what you are talking about in my head, im a hands on type of person.
Old Feb 14, 2010 | 08:25 PM
454navyss's Avatar
having 8 lights on a circuit is all i would put on one circuit, i always try to put no more than 8 openings on a circuit. meaning one recepticle or one light= one opening
Old Feb 14, 2010 | 09:03 PM
Tootall's Avatar
hows this ?
Old Feb 14, 2010 | 09:24 PM
454navyss's Avatar
looks like you have everything right, just make sure you wire the switches to work with each other
Old Feb 14, 2010 | 09:27 PM
lady3bglover's Avatar
Matt, are y'all planning to build a topper to the patio?
Old Feb 14, 2010 | 09:32 PM
454navyss's Avatar
what size wire are you pulling from the breaker panel? i would probably use some 12/3 with ground. and how many lights are on the fans? you might consider pulling another circuit for just the fans just to stay safe
Old Feb 14, 2010 | 09:34 PM
Tootall's Avatar
yeah . . . that's what I'm having trouble with . . . double dimmers . . .
sure did . . . been trying to wire it up.
We'll hook up this week after work. I got your text, but it was much later.
Old Feb 14, 2010 | 09:49 PM
Congrats on the addition... to the house that is. I know that Eric and I are glad we had the steel roof extended over the patio. And I think Bella and Tank are in agreement as well.
Just let me know.. making ride to SAR on Saturday morning.
Old Feb 14, 2010 | 09:52 PM
Tootall's Avatar
breaker box to the patio is a single 12/3, 20amp breaker
3 lights per fan = 6 total . . . on a 2 way switch
8 lights 50w each on 2, 3-way dimmers (can't figure out the diagram)
2 random plugs will be added for small stuff like Christmas lights
1 quad to be added for SAT TV, small 4.1 sound system, and 32-42" TV
