HELP! Reduced Engine Power..
Old Feb 1, 2012 | 10:04 PM
BadBadBird's Avatar
Default HELP! Reduced Engine Power..
My truck is giving the reduced engine power message on the message center. Please help. Any ideas will be much appreciated
Old Feb 1, 2012 | 10:05 PM
BlackGMC's Avatar
Resident Retard
What have you done to your truck recently?
Old Feb 1, 2012 | 10:15 PM
BadBadBird's Avatar
Nothing but a tune. But it did it before and it's getting progressively worse
Old Feb 1, 2012 | 10:18 PM
BadBadBird's Avatar
Nothing but a tune. But it was doing it before the tune. It's getting progressively worse
Old Feb 2, 2012 | 10:53 AM
blackcash's Avatar
Clean the throttle body, that's a start. Or straight replace it if you can find a spare to test out.
Old Feb 2, 2012 | 12:35 PM
Tombstone's Avatar
What year truck? I know the new bodystyle Escalades are haveing issues with the tps causeing that issue which should be the same one they use on the trucks.
Old Feb 6, 2012 | 04:13 PM
Damn, my 03 Silverado is also having the same problem. I replaced the throttle body connector, pedal, and even changed the throttle body but no luck! What else is recommended to check. This started after I got a tune. Any help is appreciated...
Old Feb 7, 2012 | 06:58 PM
Gadgetized's Avatar
Pull on the Brown and Yellow wires by the TB. If they are broken, you will feel the insulation stretch. Replace or repair the broken wire.
superchomper2003
Aug 26, 2015 09:39 AM
DrX
Aug 11, 2015 07:25 AM
GMCtrk
38
Aug 9, 2015 08:50 PM
Ferocity02
Aug 7, 2015 08:50 PM
85SS/85GN
Jul 22, 2015 12:48 PM
