Finally broke down
Old Aug 15, 2005 | 09:30 PM
CHAGO's Avatar
Default Finally broke down
I finally broke down and am buying some escalade handles for the CC
Figure I couldnt beat $172 for all 4 handles. Does anyone know if the panels on the rear doors pop off the clips like the ones in the front do?
Old Aug 16, 2005 | 12:49 AM
ap2002's Avatar
I am not sure but I think the back panels pop off different??? when I had my speakers replaced on my wifes cc they found out it was a different method to take off the rear panels....
Old Aug 16, 2005 | 06:17 AM
CHAGO's Avatar
damnit, guess I'll have to find somewhere to install them.
friend of mine said the guy at the stealership charges $100, but thats a bit high in my opinion for 12 screws.
Old Aug 16, 2005 | 07:10 AM
ap2002's Avatar
I would look for any body shop, they would be able to do it for cheaper.... or go to any little audio store and they should be able to tell you how to take off the panels...
Old Aug 16, 2005 | 07:12 AM
CHAGO's Avatar
I'll give my usual bodyshop a call, but only problem is they are in 2nd ward
Old Aug 16, 2005 | 07:16 AM
ap2002's Avatar
that shouldn't be a problem, just were a bullet proof vest!!!!
Old Aug 16, 2005 | 07:30 AM
CHAGO's Avatar
no ****! they do some good work tho, and the owner is friends of the family.
you should see some of the candy paint jobs they put out
Old Aug 16, 2005 | 07:41 AM
leochevy2001's Avatar
just pull'em off!
Old Aug 16, 2005 | 07:47 AM
CHAGO's Avatar
Originally Posted by leochevy2001
just pull'em off!
**** I'm very accident prone when it comes to doing stuff on my truck, so I'd rather pay someone and be safe!!!!
Old Aug 16, 2005 | 09:22 AM
Neil 6.0's Avatar
From: as far away from Koonerville as humanly possible
It's been a while since I took mine off for anything, but I think they are easier to remove than the fronts. Gently pry off the door lock cover thingy. Pop off the window switch cover, unplug it. Take out the screw that is in there and the screw that is under the grab handle and yank that sucker up & out. I don't think you even have to unplug the speakers, just position the panel where you can work around it.
