Finally broke down
I finally broke down and am buying some escalade handles for the CC
Figure I couldnt beat $172 for all 4 handles. Does anyone know if the panels on the rear doors pop off the clips like the ones in the front do?
Originally Posted by ap2002
I am not sure but I think the back panels pop off different??? when I had my speakers replaced on my wifes cc they found out it was a different method to take off the rear panels....
friend of mine said the guy at the stealership charges $100, but thats a bit high in my opinion for 12 screws.
I would look for any body shop, they would be able to do it for cheaper.... or go to any little audio store and they should be able to tell you how to take off the panels...
that shouldn't be a problem, just were a bullet proof vest!!!!
you should see some of the candy paint jobs they put out
From: as far away from Koonerville as humanly possible
It's been a while since I took mine off for anything, but I think they are easier to remove than the fronts. Gently pry off the door lock cover thingy. Pop off the window switch cover, unplug it. Take out the screw that is in there and the screw that is under the grab handle and yank that sucker up & out. I don't think you even have to unplug the speakers, just position the panel where you can work around it.
