Contemplating Buying BEATER
Old Jan 15, 2010 | 09:15 PM
Ender06's Avatar
Default Contemplating Buying BEATER
So a friend of mine has a 85 4x4 S-10. Body and frame are perfect condition, but its got a few little problems. It is a 2.8L 4speed straight. It seems the throw out bearing is squeaking horribly, and a few of the guages are way off or not woking, but I just need a beater and something a little less thirsty than the old 8.1L. So a few questions: how hard is it to put a new throw out bearing in it?? How reliable are the old 2.8's?? And would that tranny bolt up to a fairly new 4.3?? And how hard would the swap be?? I can get one fairly cheap, and might be a little more trust-worthy.
Old Jan 15, 2010 | 10:29 PM
cheyenne383's Avatar
TOWN CRIER
The 4.3 will not bolt up to the trans, it has a SBC/90 degree bellhousing and the 2.8 has a V6/60 degree bellhousing. The throwout bearing is as easy as putting a clutch in it, that's basically what you are doing (I would honestly go ahead a get a clutch and pilot bearing while you're in there if it was me). I have put a LOT of miles on several different 2.8s in Camaros, S10s, and Blazers without any issues. I have lost oil pressure in 1 of them, but I think that was a driver issue more than it was the vehicle. They have no torque whatsoever, but the 5 speed S10s aren't all that bad, they weigh less than 3k lbs.
If you get the 2.8s, an SBC V8 swap is actually easier than a 4.3 swap, with the right mounts it damn near a bolt in process... just a little FYI.
Old Jan 15, 2010 | 10:41 PM
Ender06's Avatar
OK, thanks. So what motor would you suggest to be the EASIEST??
Old Jan 16, 2010 | 07:26 PM
viciousknid's Avatar
Where's the Beef?
The 4.3 and SBC Will be about the same difficulty if the 4.3 is carbed. if it has a TB then it's a little more work cuz you have to swap the electronics. (IIRC)
Either put a 2.8 back in it or find a Gen 1 small block and trans for it. Custom oil pan, buy or make motor mount adapters. Shorty headers or manifolds and make everything mechanical.
Old Jan 16, 2010 | 11:00 PM
Ender06's Avatar
Well that would be sweet, but this is just a budget beater. Dont wanna dump a whole lotta cash in it. Just want it to be reliable
Old Jan 16, 2010 | 11:05 PM
Where's the Beef?
Those 2.8's are GUTLESS btw.
Old Jan 16, 2010 | 11:12 PM
Ender06's Avatar
Yeah, i figured that. What kinda mileage they get??
Old Jan 16, 2010 | 11:38 PM
Where's the Beef?
I had one in an 89 Camaro RS. Can't remember what I avgd but it seems around the same as my 4.3 S10 blazer which was around 16-17 tops.
I'm sure the camaro MIGHT have been a little better but can't remember for sure. All i really remember his how slow it was.
Fuel Economy.gov says 25mpg in the camaro. 22 in s10 blazer and pickup 4wd
Old Jan 17, 2010 | 12:01 AM
Ender06's Avatar
well i guess anything in the teens is better than 7mpg in the 8.1L
Old Jan 17, 2010 | 12:06 AM
Where's the Beef?
Conditioin says a lot.
My dads 2.2 was getting 29mpg back in 06 when I drove it and now i'm gettint 20 in it. I suspect a leaky injector but you have to take the intake off just to see the injectors
