can anybody figure this game out?
ive been playing it off and on for a little bit and i cant get anywhere on it.
http://www.ebaumsworld.com/games/submachine.html
Adkoonerstrator
Look at the coin. It has some numbers on it, maybe a combination....
Get the tile piece out of the box once you use the combination. Get the fuse also and use it on the electric panel. Then go down to the room with the electric switch and throw it on. Then put the spoon across the electric arc and wait for it to blow.
Put the valve on the pipe with the three pistons and spin it a couple times and you'll hear a pipe bust. Go to the room with the leaky pipe and pick up the pearl.
Use the pearl on the clock string. Get the tile piece outta the clock.
Hmmm...what else. Go do that and see if you can get it done.
Put the tile pieces in the place on the wall in the first room you were in. Once you get all 4 in there the game is pretty much over.
Get the tile piece out of the box once you use the combination. Get the fuse also and use it on the electric panel. Then go down to the room with the electric switch and throw it on. Then put the spoon across the electric arc and wait for it to blow. Put the valve on the pipe with the three pistons and spin it a couple times and you'll hear a pipe bust. Go to the room with the leaky pipe and pick up the pearl.
Adkoonerstrator
Originally Posted by fogle04
dang pipe wont bust. i dont have any speakers on this comp at work so i just keep spinning then go look.
I love games like that.
