Any of you guys work at a GM dealer??
Old Jun 18, 2010 | 07:35 PM
Mangled03gmc's Avatar
Baltimore Whore
Question Any of you guys work at a GM dealer??
If so, tell me exactly how to get the rear door panel off a 2004 cady deville. I need to fix the window motor on mom duks car, don't want to break anything- tabs ect trying to get it off. Thanks
Old Jun 18, 2010 | 08:39 PM
scooter k's Avatar
xTooltipElement
Service Information
2004 Cadillac DeVille | DeVille (VIN K) Service Manual | Body | Doors | Repair Instructions | Document ID: 509860
Rear Side Door Trim Panel Replacement (Standard)
Tools Required
J 36796 Clip Zip Clip Removal Tool or J 38778 Door Trim Pad Clip Remover
Removal Procedure
•Position the window fully downward.
•Ensure the manual lock **** (1) is in the unlock position.
•Insert a flat bladed tool into the top service notch in order to disengage the locking clip (2) located at the front of the manual lock **** (1).
•Remove the manual lock **** (1).
•Remove the inside handle bezel from the inner door panel in the following order:
5.1. Hold the inside handle to the open position.
5.2. Insert a flat bladed tool at the front lower corner of the bezel.
5.3. Pry outward on the bezel.
5.4. Remove the bezel from the inner door panel.
•Remove the screw attaching the inside door handle to the sheet metal.
•Use the J 36796 or J 38778 in order to release the eight retainers (1) around the outside edges of the door trim panel.
•Slide the door trim panel (1) upwards to release it from the following:
• The alignment datums (4)
• The eight retainers
• The arm rest steel retainer clips (3)
• The inner belt molding (2)
•Disconnect the door trim panel electrical connector.
Installation Procedure
•Position the manual lock rod (1) vertically into the bell crank retainer clip (2).
•Slide the electrical connector (4) into position on the water deflector (1).
•Remove the steel retainer clips (2) from the arm rest pull handle brackets.
•Slide the steel clips (2) into the nylon nuts (3).
•Install the door trim panel to the inner door in the following order:
5.1. Position the door trim panel (1) downward over the following:
• The manual lock rod
5.2. Engage the door trim panel simultaneously into the following:
• The electrical connector
• The armrest pull handle retainer clips (3)
Caution: This screw must be properly installed. This screw is critical in order to maintain retention of the inside handle to the slider-glide mechanism. Failure to properly install this screw may allow the door to unlatch during a collision, resulting in personal injury.
Notice: Use the correct fastener in the correct location. Replacement fasteners must be the correct part number for that application. Fasteners requiring replacement or fasteners requiring the use of thread locking compound or sealant are identified in the service procedure. Do not use paints, lubricants, or corrosion inhibitors on fasteners or fastener joint surfaces unless specified. These coatings affect fastener torque and joint clamping force and may damage the fastener. Use the correct tightening sequence and specifications when installing fasteners in order to avoid damage to parts and systems.
•Install the screw attaching the inside door handle to the sheet metal.
Tighten
Tighten the screw to 0.5 N·m (4 lb in).
•Install the inside handle bezel to the inner door panel in the following order:
7.1. Hold the inside handle to the open position.
7.2. Insert the rear hook on the bezel to the wood trim tab.
7.3. Press the forward end of the bezel inward until it is fully seated.
Important: Ensure the manual lock rod is in the full up/unlocked position.
•Position the manual lock **** (1) into the bezel opening until the locking clip (2) bottoms out on the bezel.
•Engage the locking clip (2) located at the front of the lock **** (1) to the lock rod.
© 2010 General Motors. All rights reserved.
Old Jun 18, 2010 | 08:40 PM
scooter k's Avatar
Sorry. Pictures wouldn't post.
Old Jun 18, 2010 | 09:40 PM
2005 Silverado's Avatar
SPAM HUNTER
Somebody is using Alldatapro...i just IM him on aim the exact same lift of instructions haha
Old Jun 18, 2010 | 10:27 PM
Baltimore Whore
Awsome thanks man
Old Jun 19, 2010 | 12:04 AM
silver-mod-o's Avatar
Hunt&Fisherator
I work at a ford dealership. Sorry
Old Jun 19, 2010 | 12:06 AM
Dewey's Avatar
no, we're sorry... for you that is
Old Jun 19, 2010 | 03:12 AM
BadAssChevy327's Avatar
why he has job security. there always breaking down.
its the chevy mechanics i feel bad for. besides tranny and g80 stuff they have no work ... lol
Old Jun 19, 2010 | 08:37 AM
scooter k's Avatar
Oh the chevy's seem to break too. Lots of oil burning going on with 2007 tahoe's, suburban's, and silverado's right now.
Old Jun 20, 2010 | 10:24 PM
Hunt&Fisherator
I guess I need to take a pic of the inside of our shop and go across the road and snap a pic inside the gm shop and see who has the most work lol
