Any Dirt Track Racers?
Old Aug 21, 2007 | 08:33 PM
dirt track racer 81's Avatar
Default Any Dirt Track Racers?
just wondering if any one on here races?? i got some questions on a 3 link with a j-bar set up..need forward bite...kyle maybe you can help me
Old Aug 22, 2007 | 02:01 PM
kbracing96's Avatar
More forward bit, here a few ideas.
More cross weight
More rear weight
More pinion angle
Raise the right side of the J bar
Lower the front of the upper 3 link bar
Raise the front of the lower 3 ling bars
Soak the tires in toluene
Less timing in the motor.
A driver with a softer foot
There's a few ideas for forward forward bite.
Old Aug 23, 2007 | 06:24 PM
[QUOTE=kbracing96]
QUOTE]
i got a rotissery i can put 4 tires on and roll them and soak them...
believe me when i baby the gas other cars are pullin away..
Old Aug 23, 2007 | 06:39 PM
CHEVRACER83's Avatar
I RACED A DIRT TRACK CAR OUT HERE AT PERRIS VALLEY.... MY BUDDY WHO NORMALLY RUNS IT CRACKED 3 RIBS IN A CAR ACCIDENT, SO I OFFERED TO STRAP IN... IVE RACED A FEW DIFFERENT CLASSES AT STREETS AT WILLOW IN NORTHERN CAL. DIRT IS WAYYYYYYY DIFFERENT..... YOU GUYS HAVE MY UTMOST RESPECT FOR WHAT YOU CAN DO I COULDNT GET THAT CAR TO SETTLE TO SAVE MY LIFE, AND WHEN THEY ASKED ME WHAT WAS WRONG ALLI COULD SAY WAS THE *** END WAS LOOSE AS HELL
Old Aug 23, 2007 | 06:45 PM
your always on the verge of spinnin out in a dirt car..yuo have to be loose enough but not too loose that your loosin ground wich im doing now...im just as fast as the fastest cars going down the straightaway and goin in the corner but they get me coming out of the corner...i just say **** it and floor it coming out..its the only way i can keep up..ive had alot of people tell me my tires are smokin comin out of the corners
Old Aug 23, 2007 | 06:55 PM
DAMN... LIKE I SAID.... I HAVE ALOT OF RESPECT FOR THAT..... I HAVE LOGGED ALOT OF ROAD COURSE TIME.... NOTHING COMPARES TO THE AMOUNT OF SKILL IT TAKES TO KEEP A DIRT CAR ON THE TRACK....
LETS JUST SAY I WAS SLOWER THAN EVERYBODY OUT THERE..... EVERY TIME I FLOORED IT IN THE TURNS I WOUND UP ALMOST SIDEWAYS.
SORRY DIDNT MEAN TO TAKE YOU OFF TOPIC....
IF IM EVER IN TAHT AREA I MAY HAVE TO STOP BY AND SEE YOU IN ACTION. I AM REALLUY INTERESTED IN THE TUNING ASPECT OF THOSE THINGS.... THEY ARE REALLY BITCHEN MACHINES
Old Aug 23, 2007 | 07:03 PM
its crossed my mind to stick some 4.10 gears in it and take it to a road coarse in tulsa..i know a few guys have done it..yes they are bitchen machines haha..ive had alot of people ask me how they accelerate and i just say how my truck accelerates from a 25 punch with the n2o is what its like coming out of a corner and at 75 and get to 95 in a 2-3 seconds..they do accelerate..on the mustang dyno it does a pull from 3000 rpm to 7500 in 3 seconds...tuning the suspension can be a nightmare and still is..all differents kinds of shocks and springs and tires sizes and compounds..each corner of the car has a different tire size, shock, spring and ride heights..
Old Aug 23, 2007 | 07:27 PM
kbracing96's Avatar
What kind of track conditions are you trying to setup for? Dry slick I'm guessing, so you need more of an asfalt like setup. If you smoking the rr, you need to get that lr working for ya a little more. Maybe a softer shock there. I'm guessing you have 4's on the back now anyway. More cross weight would help that to. Can you sype your tires?
Old Aug 23, 2007 | 08:38 PM
im smokin both..on the right rear i got an afco 94 and on the left rear i gotta afco 93/5..im running a j-bar from the left side of the frame to the pinion..not from the right side like most asfalt cars..the car does have body roll to it and occasionally pulls the left front around 2-4 inches when it does hook up..typically in hot laps and heat race when its tacky..im runnin 50.5% cross in it now and 54% rear..two things i am changing right now is the 3rd link.. i was told by several people that im running too much angle..i used to have the bar up two holes and i had no problems with this..and its one thing i completely forgot about..i guess some time after my wreck i guess i put it back down in the lower hole..i do sipe my tires..another thing with my tires on my grooving that im changing to hopefully get more forward bite..i originally grooved the horizontal lines at an angle like the tire on the left and now im regrooving actuall horizontal lines on them ..like the tire i just got done with on the right
and yes for you guys wondering i did groove those freehand with a groovin iron
AdaMax
May 16, 2016 11:35 PM
Vortec350ss
Jan 12, 2016 10:36 PM
nabozny21
Oct 17, 2015 07:47 PM
Wolftrk99
Oct 2, 2015 08:17 AM
Slammed silverado
Sep 28, 2015 06:14 PM
