am i F'd
Old Oct 26, 2010 | 05:37 PM
454navyss's Avatar
i dont want to tack the cam, i stil want it to be fully functional. any ideas on what i could use as a stud?
Old Oct 26, 2010 | 06:07 PM
Bigredmariner's Avatar
Go to the hardware store and find a few dowel pins that are close to the size. You could slip it in and try tacking the back side then grinding it back down flush so it clears when the A arm moves. That's about all I got.
Old Oct 26, 2010 | 06:11 PM
454navyss's Avatar
thats a good idea, thanks
Old Oct 26, 2010 | 06:45 PM
jared91's Avatar
call a gm service rep and find out what you need to fix it CORRECTLY perhaps??
Old Oct 26, 2010 | 08:09 PM
454navyss's Avatar
i am going to thread the hole and put a bolt in it then weld it on the inside, grind the weld smooth and cut the head off
Old Oct 26, 2010 | 08:11 PM
That would work too. Good luck.
Old Nov 1, 2010 | 08:18 AM
silver-mod-o's Avatar
Hunt&Fisherator
JB weld that bish....
Old Nov 1, 2010 | 11:47 AM
budhayes3's Avatar
PT's Slowest Truck
I'm sure that the factory pin is hardened, and probably only a couple of bucks if available...go to the dealership and order the right part so you don't end up repeatedly snapping aftermarket bolts and whatnot...
Old Nov 1, 2010 | 04:58 PM
iamkeniff's Avatar
just pull it apart and change it....
