am i F'd
Go to the hardware store and find a few dowel pins that are close to the size. You could slip it in and try tacking the back side then grinding it back down flush so it clears when the A arm moves. That's about all I got.
I'm sure that the factory pin is hardened, and probably only a couple of bucks if available...go to the dealership and order the right part so you don't end up repeatedly snapping aftermarket bolts and whatnot...
