TrailBlazer SS Suspension | Wheels | Tires | Drivetrain |Engine | Body | News
HID head lights
Old Mar 3, 2009 | 11:45 AM
evo45's Avatar
Registered User
Default HID head lights
I bought a set of HID headlights for my TBSS and when they are in daytime running light mode only one will light up. It isn't consistent with which one it is either. I can get both of them to light up if I turn the headlights on with the switch but only one will come on when it is put into gear. Does anyone have a suggestion on how to get both of them to light up while on daytime running light mode? Thanks Vic
Old Mar 3, 2009 | 12:16 PM
Tootall's Avatar
you'll need a relay harness
get on TBSSowners dot com . . . there's a DRL killer on there that works.
Old Mar 3, 2009 | 02:16 PM
evo45's Avatar
Registered User
What is a drl killer? I searched it at that site and didnt find anything.
Old Mar 3, 2009 | 05:09 PM
andrew383's Avatar
traveling mod
http://www.tbssowners.com/forums/showthread.php?t=418
http://www.tbssowners.com/forums/forumdisplay.php?f=138
Old Mar 3, 2009 | 09:48 PM
evo45's Avatar
Registered User
Thanks for the links Andrew. I really dont want to cut my harness, but to save my lights I think I am going to do it. I'll look into it tomorrow. Which option did you go with, the mod under the seat or under the hood?
Also do you know if the Sierra pickups have 70% power going to the headlights for the daytime running lights? Thanks
Old Mar 18, 2009 | 08:06 PM
XenonGate's Avatar
Former Vendor
Yes, a relay should solve this issue.
Old Mar 22, 2009 | 01:54 AM
07 classic n lower have the drl beside the front signal lights
Old Apr 27, 2009 | 09:10 PM
jetttstream's Avatar
let me know if you figured this out, I might be able to help. v-leds has a DRL module that takes the pwm signal and outputs a clean 14v signal (need a relay harness as well) but it's 25 bucks well spent and no wires to cut
-Mike
Old Apr 28, 2009 | 07:47 PM
Blown02Sierra's Avatar
all it takes is a large enough capacitor between the headlight on wire and a ground to give the relay a constant signal. Also, a large enough capacitor will keep the headlights on for a short while after the signal shuts off which is pretty cool.
Bluchevypick
Aug 18, 2015 09:11 AM
Ketis
Jul 23, 2015 12:37 PM
Ammadien
Jul 22, 2015 08:50 PM
Offroadunleashed
Jul 20, 2015 02:25 PM
