TrailBlazer SS Suspension | Wheels | Tires | Drivetrain |Engine | Body | News
5.3 06 Trailblazer,does it belong in here??
Old Jul 27, 2016 | 07:51 PM
gonzo 6.2's Avatar
Default 5.3 06 Trailblazer,does it belong in here??need advise
Just bought an 06 TB 5.3 rod knocking.Will bring it home tomorrow,I have to decide how to go about this.Do I repair it on the cheap or do I make a little bit of a hot rod out of it? Buy a new or used 5.7 crank then bore it to 5.7 I have a set of like new LS1 pistons on rods,then mild cam and exhaust it then I guess I would need better heads like some 243s.If I put some money in it I may keep it for awhile.Im open for ideas for budget builds what blocks interchange ect.
LH6 engine
Thanks
Old Jul 27, 2016 | 11:36 PM
Wolftrk99's Avatar
Isnt the lh6 the bastard gen 3/4 block that they started incorporating the gen iv stuff into??
Old Jul 27, 2016 | 11:50 PM
Vortec350ss's Avatar
Dude I did this exact build with a 5.3 Saab that I turned into a 6,0 with anL96
It ripped. It had an LS6 cam and a 3000 converter. The cam left a lot on the table without a doubt. But the car ripped. The LS6 And LS3 are very similar but the LS6 has more exhaust duration believe it or not.
That's the route is take again without hesitation. Sell The parts off the 5.3 for what they're worth and move on.
Old Jul 27, 2016 | 11:53 PM
gonzo 6.2's Avatar
Hey wolf pack thanks for jumping in
Im just starting to learn these,sounds like the 05 is a 24 wheel the 06 is the 58,the newer X,its dod,just trying to figure out what will go in or what can I do with this one, read something about the 07 truck 5.3 may plug in,which that I assume is an iron block,the L33 HO,dont know if that will work,it has no dod i dont think,yes first of the gen 4 I guess,im open to all ideas,i have not pulled any engine out of a Tblazer,reading some say its a ****.Feel free share.
Old Jul 28, 2016 | 12:05 AM
gonzo 6.2's Avatar
Its why I called on you bro,I knew you did something wasnt sure what.You buy a longblock? plug and play after the cam swap? L96 3/4 truck 6.0 i think
Old Jul 28, 2016 | 08:12 AM
Yes I bought a long block. I swapped cams to delete VVT. The HD motors do not have DOD, but they do have VVT and i didnt have the harness to control that on the car. I also wanted more power...
Old Jul 28, 2016 | 05:24 PM
gonzo 6.2's Avatar
Hey bud what heads castings were on that L96 ? do you know other long blocks that will match up just as well? thanks
Old Jul 28, 2016 | 07:17 PM
Wolftrk99's Avatar
L96 should have 5364, 823 or in rare instance 0821 heads...
Old Jul 29, 2016 | 12:29 AM
gonzo 6.2's Avatar
Ok so they are the rectangle ports,the engine in it still has the old cathedral ports.
dang Dudes I have a core L92 longblock,im saving it to build something expensive.
This TB is decent shape with 180k miles,paid little for it but when its dialed in its still not worth a whole lot of $$$ I need to do this on a budget.Well if I go the route going crank kit a rod and a cam change,still going to be some dough,just need to try and find the dealo
Old Jul 29, 2016 | 02:24 AM
Wolftrk99's Avatar
Haha im building a somewhat budget l92 myself right now.... I will have maybe $2000 in it total when its all said and done....
