5.3 06 Trailblazer,does it belong in here??
You can swap to a square port engine very easily... you literally only need the 87mm truck square port intake and all else bolts right in.
The Iron block square port motors can be had a hell of a lot cheaper than the alum 5.3 can. And it makes a hell of a lot more power.
After selling the block and the heads you wont be into it for much... less than 1k.
Dude I did this exact build with a 5.3 Saab that I turned into a 6,0 with anL96
It ripped. It had an LS6 cam and a 3000 converter. The cam left a lot on the table without a doubt. But the car ripped. The LS6 And LS3 are very similar but the LS6 has more exhaust duration believe it or not.
That's the route is take again without hesitation. Sell The parts off the 5.3 for what they're worth and move on.
I am seeing a few resonable,by resonable I mean not stupid money for 100k mi L96s on carpart and will have shipping costs.Summit has a baby TQ cam decent priced and good Ol LS6 spring are a good deal.
Cam Style: Hydraulic roller tappet
Basic Operating RPM Range: 2,000-6,000
Intake Duration at 050 inch Lift: 216
Exhaust Duration at 050 inch Lift: 220
Duration at 050 inch Lift: 216 int./220 exh.
Advertised Intake Duration: 285
Advertised Exhaust Duration: 292
Advertised Duration: 285 int./292 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.560 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.560 in.
Valve Lift with Factory Rocker Arm Ratio: 0.560 int./0.560 exh.
Lobe Separation (degrees): 114
Camshaft Gear Attachment: 3-bolt
BTR LS3 N/A STAGE II 3 BOLT CAM This is the one btr recommended, and i am running.... Night and day difference over the comp cams xr275hr i had in there!!!
You tell me if you think "cost me a motor" was an over statement.
He recommend 1211x PAC springs for my 2010 Silverado 6.2 LS9 cam and boosted and had ARHs
spring broke,dropped valve less than 20k miles,took out a piston and a head.So then it all went back stock.Talked to 2 other "gurus",they said that was not the spring for that cam,better off with LS6 springs.
Garrett12895
02-22-2016 10:42 AM
