TOWING & OFFROAD PERFORMANCE Towing |Suspension | Wheels | Tires | Drivetrain |where the pavement ends.
What size tire for 4" procomp lift?
Old 03-27-2007, 09:00 PM
Z71/99's Avatar
Default What size tire for 4" procomp lift?
I have a white extended cab z71 with a 4" procomp lft on it with the factory 16" wheels with 295/75 BFG's that are almost done for and figured its about time for an upgrade. Im going to get some new 16's(prob. eagle alloys) I was just wondering what the biggest size tires I could fit and maybe some cheaper tire selections I could take a look at. Thanks a lot.
Old 03-29-2007, 06:41 PM
WhiteZ_02's Avatar
If you get 16x10 i think the biggest thing you can run is a 305 70 16
If you get 16x8 you should be able to run 315 75 16
Somebody correct me if im wrong
Old 03-30-2007, 01:50 PM
RandomHero's Avatar
I didn't even know pro comp made a 4" kit. I was only aware of their full 6" drop kit that you can crank to 7.5"
Old 04-02-2007, 03:46 PM
01-Z71's Avatar
personally I wouldnt go over 305 or 33" that way your not over stuffed and you have some articulation!
Old 04-02-2007, 06:59 PM
99LoweredSierra's Avatar
33" is prolly going to be your max!
Old 04-03-2007, 05:27 AM
Import Moderator
beastmode's Avatar
+1
ranchos 4" i think you can do a 305/70/16
on a side note just for your reference, you can run 285/75/16 with JUST the torsion bars cranked on a 1/2 ton which is about a 32.8x11.5
Old 04-03-2007, 09:52 AM
xsports33's Avatar
33" tires would fit well. 35's would definitely rub, even if you were cranked all the way and trimmed. With 33's you wont' have to crank your keys all the way and your ride won't suffer... much
Old 04-03-2007, 10:05 AM
Import Moderator
beastmode's Avatar
actually that all depends on if its a true 4" lift or if getting the lift involves cranking the tbars cause some lifts do
southernsmoker
08-31-2015 03:09 PM
maxspeed05V
08-12-2015 06:29 PM
FlowmasterMufflers
07-30-2015 05:03 PM
jrplz
07-09-2015 12:07 AM
Quick Reply: What size tire for 4" procomp lift?
