What size tire for 4" procomp lift?
I have a white extended cab z71 with a 4" procomp lft on it with the factory 16" wheels with 295/75 BFG's that are almost done for and figured its about time for an upgrade. Im going to get some new 16's(prob. eagle alloys) I was just wondering what the biggest size tires I could fit and maybe some cheaper tire selections I could take a look at. Thanks a lot.
Guest
Posts: n/a
Nah i was about to say the same thing. 305 is basically a 33" tire and the 315 is closer to a 35. I wouldn't go much over a 305 or 33" tire. I have a 4" Rancho and I run 20's right now on 33" tires but before I went to these I had 305/70/16 DC fun Country II's on a 16x10 and they fit just fine without rubbing. But it was damn close
Import Moderator
Originally Posted by RandomHero
I didn't even know pro comp made a 4" kit. I was only aware of their full 6" drop kit that you can crank to 7.5"
ranchos 4" i think you can do a 305/70/16
on a side note just for your reference, you can run 285/75/16 with JUST the torsion bars cranked on a 1/2 ton which is about a 32.8x11.5
33" tires would fit well. 35's would definitely rub, even if you were cranked all the way and trimmed. With 33's you wont' have to crank your keys all the way and your ride won't suffer... much
FlowmasterMufflers
07-30-2015 05:03 PM
