TOWING & OFFROAD PERFORMANCE Towing |Suspension | Wheels | Tires | Drivetrain |where the pavement ends.
Towing setup and 4.56 with 33s
Old May 18, 2012 | 12:41 PM
pewterliftedz's Avatar
Default Towing setup and 4.56 with 33s
Well im gonna be towing my travel trailer 9 hours next month for work, and the truck barely pulls it now with the 3.73s in 3rd gear on flat land haha. So the truck is going into the shop on Tuesday for 4.56s and Tru trac.
Truck is a CCSB 5.3/4l60e 4wd, probably a little over 6k with the loaded tool box, 33s, and grill guard.
only mods are intake, cat-back, HP tuners tune,and LS3 Throttle Body.
Travel Trailer is about 8000lbs loaded with electric Trailer brakes.
Truck is equip with a Trailer Brake controller, that helps alot.
Towing mirrors are on order.
Tru cool 40k is sitting here in my room as well as a Deep Transmission pan and new trans filter.
My main concern is making this 60e last till I can have time for put in 80e. I wanted a 6 speed, but thats not going to be an option with the 4.56s lol.
Old May 18, 2012 | 02:36 PM
iamkeniff's Avatar
4:56s wont hurt with the 6spd....just run a 37" tire
Old May 18, 2012 | 09:09 PM
andrew383's Avatar
traveling mod
Taking it easy is the main thing..I pulled mine from Indiana to Cotulla in january and runnin 3rd the whole way pretty much on a stock 60 with just servos 40k cooler and it did just fine !!
What job you goin to and electrician??
Old May 18, 2012 | 09:34 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Id do 4.30s or 4.10s if I were you. Unloaded mileage on the highway is going to BLOW with 33s and 4.56s. Ive ran the math and 4.10s with true 33s is the way to go IMO and theyd still work well with a 6L80e. Youve got to do the 6 speed
Old May 19, 2012 | 02:58 PM
I just graduated with a civil engineering degree. I'm going to be working for Halliburton as a Field Engineer in Frac.
Cody I just can't see spending the money on swapping from 3.73s to 4.10s. The 6 speed would be sweet, but I don't like that nobody has figured out the TU/TD. If I do go 6 speed, I guess that will force me togo 6" lift and 35s haha. The next mod after gears will be removing the DOD lifters and a cam. I'm thinkin maybe 220/220. Then tranny and converter.
I forgot to mention that I do have a weight distribution hitch.
Old May 19, 2012 | 03:29 PM
whitedakota's Avatar
I have 4.56's with a 285 almost 33". And I pull a big lifted k5 blazer on 38's with winch, tools, on a 18 foot trailer 450r ATv in the bed. And it pulls fine. It'll lock the converter in overdrive on flatland at 75mph. My fuel milage unloaded isn't terrible either. I say go for the 4.56's!
Old May 20, 2012 | 12:58 AM
Ya my plan was to switch the rear and see how I like he gear before doing the front. Due to needing to be in Odessa by June 3rd, just need to make the switch and break them in.
I'm waiting on a quote from Ron for 4.30s, as well as avalibility. Might go that route if avalible.
Old May 20, 2012 | 01:04 AM
AKlowriderZ71's Avatar
11 Second Hall Moniter
I run 4.10's with a 31.5" tire. I wouldn't hesitate to run 4.56's with a 33" tire, especially if you're gonna tow. Go for it!
Old May 20, 2012 | 03:22 AM
rjwz28's Avatar
Man Motor club
There are at least a couple guys on here with six-speeds and 4.56s, one on 33s and one on factory size rubber. Also, the 2500HD comes standard with 4.10s and little 245s (245/75-16 through 2010, 245/70-17 2011+) and they drive just fine on the highway. I would do the 4.56s if that's what you want right now, and the 6-speed down the road as long as you never plan to drop back to 31s.
Old May 20, 2012 | 03:29 AM
rjwz28's Avatar
Man Motor club
It would just give you a ton of bottom-end torque after the trans swap; you would actually drop a few rpm on the highway after you put in the six-speed due to a .03 taller gear ratio on the 6L80E (.67 sixth vs .70 fourth). It actually sounds like a pretty sweet setup to me.
