TOWING & OFFROAD PERFORMANCE Towing |Suspension | Wheels | Tires | Drivetrain |where the pavement ends.
spindles
Old Oct 16, 2006 | 09:21 PM
99stepside's Avatar
Default spindles
ive got a 2000 gmc rcsb z71, i found some 4 inch rancho spindles out of a lift kit. would i see any lift just from the spindles? also would i have any kind of alignment or other problems doing this?
Old Oct 16, 2006 | 09:32 PM
8MC's Avatar
8MC
When you say,"out of a lift kit", did that kit include other items such as longer springs, upper and/ lower a-arms? If the spindle is intended to be used with stock a-arms, you should be fine and yes, you will see 4" of lift. When in doubt, call the manufacturer or good offroad shop.
Old Oct 16, 2006 | 09:35 PM
99stepside's Avatar
well im not really sure what else came with it. i really dont know what comes with the 4 inch rancho kit but i was assuming it was drop brackets and spindles. already emailed rancho so maybe theyll get back with me
Old Oct 16, 2006 | 09:55 PM
munchman's Avatar
you would have to have all the drop brackets for the rancho lift to be able to use the rancho spindles. with out the brackets the spindle will not fit between the control arm
Old Oct 16, 2006 | 10:06 PM
Blown02Sierra's Avatar
yeah, you need the drop brackets for the lca's otherwise they wont work right, if at all.
_ _
Old Oct 16, 2006 | 10:13 PM
mwalls54's Avatar
Need More N2O Mod
you need alot more than just the spindles for a complete kit
Old Oct 17, 2006 | 04:58 AM
99stepside's Avatar
thanks guys, i was really pretty sure that it wouldnt work but it never hurts to ask.
whitelazer
Sep 22, 2015 09:38 PM
xerox17
Sep 5, 2015 01:23 PM
YenkoST
Aug 28, 2015 01:42 PM
Allgonoshow
Jul 29, 2015 04:21 PM
