TOWING & OFFROAD PERFORMANCE Towing |Suspension | Wheels | Tires | Drivetrain |where the pavement ends.
rancho rs9000 shock failure
Old Mar 29, 2009 | 10:53 PM
jophuss36's Avatar
Default rancho rs9000 shock failure
anyone have any bad expireences with these shocks I have them on 02 sierra and theve been on for less than a year and I already have two blown shocks and a third that the dial was ripped off of. The dial wasn't fault a chunk of ice hit itbut the other two!!! I don't know if it's just a fluke or what!
Old Mar 29, 2009 | 10:58 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Had them for 30K on my Z71 and have about 15K with them on my Dmax(different shocks) with no problems.
Old Mar 30, 2009 | 08:05 AM
andrew383's Avatar
traveling mod
you talked to rancho yet?
Old Mar 30, 2009 | 04:02 PM
jophuss36's Avatar
not yet, but I talked to my local shop and they said bring em on in and they will swap them out.
Old Mar 30, 2009 | 04:08 PM
venomhp's Avatar
I ran em on three different trucks and never had a problem, sorry to hear about that
Old Mar 30, 2009 | 08:08 PM
andrew383's Avatar
traveling mod
thats good there gonna replace them but sometimes things break.
ive been thinking about running the 9000's on my truck as well
Old Mar 31, 2009 | 03:59 AM
Dgrown's Avatar
hey does rancho make shock that can take up to 7000 pounds??? thats my trucks weight before adding any thing else on to it
Old Apr 1, 2009 | 06:47 PM
getchusum99's Avatar
yes id get the 9000's or next grade up
Old Apr 1, 2009 | 07:15 PM
truckmann's Avatar
I had 9000's on my old mud truck and never had a problem with them... Only way I would get them again is if I could get the in-cab adjustment setup. Always seemed to be more trouble than it was worth crawling under the truck to make adjustments for off-road.
Old Apr 26, 2009 | 02:55 PM
jophuss36's Avatar
ok so I received my new shocks, and when taking my old shocks off I realized that they were short, because I have a leveling kit on the truck. So I bolted the new 0" lift shock to the bottom as normal, and for the top I put two bushings underneth the shock top mount, cut a third bushings in half and used it on top of the mount. This setup= about 3/4 inch lift shock. Aka perfect for leveling kits. I have a bit more articulation now, and hopefully I won't blow any more shocks at full droop.
