TOWING & OFFROAD PERFORMANCE Towing |Suspension | Wheels | Tires | Drivetrain |where the pavement ends.
NP246 problems
Old Feb 17, 2014 | 08:50 PM
BattleSausage's Avatar
Originally Posted by trxmxzx
When you say case saver is it protecting the case from the chain? Just wondering what you mean
To elaborate for you, the case is made of magnesium whereas the pump is made of aluminum. From the factory, a small clip is installed between the mating of the two and is all that protects the softer magnesium from the harder aluminum pump. Needless to say, the clips are prone to breaking. The case saver essentially is a much beefier version of the oem clip that protects the entire pump pocket of the case itself, otherwise the pump will eventually rub a small hole in the case leading to loss of fluid.
Old Feb 17, 2014 | 10:00 PM
timmay208's Avatar
im doing the merchant automotive pump rub kit in mine before it rubs through
Old Feb 17, 2014 | 10:03 PM
trxmxzx's Avatar
13 Second Truck Club
Thanks for the info
madmann26
Apr 29, 2020 09:17 AM
RustyD
May 23, 2016 07:04 PM
dsbodley
Nov 14, 2015 09:46 PM
2002_Z28_Six_Speed
Oct 4, 2015 01:34 PM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
