TOWING & OFFROAD PERFORMANCE Towing |Suspension | Wheels | Tires | Drivetrain |where the pavement ends.
modifieying front hitch extension
Old Mar 15, 2026 | 11:26 AM
thebrain's Avatar
Default modifieying front hitch extension
looks like I'll need to add another hole in reciever extension I actuely messed up the first hole but at the time of drilling I wasn't intending on using the 4" drop my 9" adjustable isn't as long an would work now I can't find where I stored it or some scumbag ran off w/ it.
note the long hitch pin at hummer is vertical.
egay front reciever extention
where I should have added hole further up
is it acceptable to reduce lenght of hitch? I'm thinking no bc it's made that lenght for a reason,plus the extra hole will be easier.
front hitch 2 inch elevated
I'm hoping it mite be easier to manuver the vessel into the corner of backyard w/ a front hitch.
I'm thinking due to the Hummers short incline angle (real short entry an exit) will be about 20"s closer to water when launching the vessel but will be much higher to avoid salty water?
additionaly I think big kid was correct on my other thread about the spare tire being in the way.heck the spare tire carrier is very close to the trailers spare.
hope this helps someone else w/ a front hitch.
Old Mar 17, 2026 | 03:12 PM
1FastBrick's Avatar
Custm2500's Rude Friend
I don't think it will hurt if you rotate it 90 degrees and put new holes. If your only using it for launching I don't see it being that big of a deal.
Nicksilverado
Jul 31, 2010 09:53 AM
KevinF56
Jan 31, 2010 01:54 PM
jasond26
Sep 18, 2008 05:47 PM
mdwatts11
Aug 21, 2007 10:05 PM
01pewter2001z28
Jan 30, 2007 12:18 PM
