TOWING & OFFROAD PERFORMANCE Towing |Suspension | Wheels | Tires | Drivetrain |where the pavement ends.
Lifting a Sierra Denali
Old Aug 6, 2011 | 10:29 AM
bgray's Avatar
TOTM: June 2007
Cognito makes a driveshaft to fix your front shaft worries
Old Aug 8, 2011 | 11:06 PM
Anyone with experience with the 3" skyjacker lift kit for awd trucks?
Old Aug 10, 2011 | 08:06 AM
I am sure Denny's Driveshafts can make you one as well.
Old Aug 13, 2011 | 11:31 AM
xrevx1's Avatar
GM 4WD 2006 GMC DENALLI 1500 CST Performance Suspension - Lift Kit, Lift Spindle, UTV Suspension Kit, Shock, Upper Arm - Chevy, Ford, Dodge, Nissan, Toyota
Old Jan 13, 2012 | 08:11 AM
kylesdenali's Avatar
Not sure how I missed this. I was going through the same thing on my truck when i bought it (2006 sierra denali) I first went with leveling keys and aal's out back gained about 2" up front without any bad vibrations. Then i got the itch to go up higher I made my own 2" body lift for $90. So I have 4" of lift and 35's in these pics. Rides like a champ. I am currently about to pull the trigger on a 6" kit and I will make the front shaft work....although I'm pretty sure my truck has the same front shaft as any other 4x4 z71. Deff no cv-like front driveshaft....
Old Apr 18, 2012 | 12:54 AM
cshiels's Avatar
Registered User
I have a 2006 sierra denali with 3" keys and have ran into some front end problems including cv axles.
Old Apr 18, 2012 | 01:04 AM
cshiels's Avatar
Registered User
Old Apr 18, 2012 | 02:31 AM
AndysC3's Avatar
I have readylift leveling keys and aal with 285/70r17s and it rides fairly smooth. Although the roads here in Tucson are crap with cracks and pot holes all over the place. I know someone with the skyjacker 3" lift. Looks good. I'll see if I can find the kit # he used.
Old Apr 18, 2012 | 10:41 AM
cshiels's Avatar
Registered User
Default denali lift
Driving down the road is pretty smooth in my denali, i have pro comp es9000 shocks on it. The problem i experience is play in the pitman/idler arms. When i kick it from a stop or rolling stop i get this terrible death wobble, the front tires start to flex inwards causing the truck to jump all over the road. Any suggestions?
Old Apr 23, 2012 | 04:02 PM
AndysC3's Avatar
check wheel bearing and tie rods. Make sure everything is tight.
