TOWING & OFFROAD PERFORMANCE Towing |Suspension | Wheels | Tires | Drivetrain |where the pavement ends.
Lift and Tires
Old Feb 26, 2006 | 03:00 PM
silverado_03_z71's Avatar
Default Lift and Tires
I am going to be lifting my truck, 2003 silverado. Do you guys change the gears in it? Also would you go with 18" tires or stay with 16's? What are your opinions? I am pretty sure i am going to go with the fabtech lift and with the instal and everything and tires if i go with 18's its going to be about 4200? Does this seem high? Any help would be appreciated.
Old Feb 26, 2006 | 06:18 PM
02sierraz71_5.3's Avatar
At work we just put a 6" fabtech on a truck like yours with 315/75 tires on 18" rock crusher wheels we had to trim a small amount these tires are around 31x 13.5
It looks like a whole new truck before it was ugly its amazing what a lift and wheel/tires will do.
Old Feb 26, 2006 | 06:44 PM
How much did that run the customer?
Old Feb 26, 2006 | 07:23 PM
NoChrome's Avatar
Isnt a 315/75 closer to a 36" tire. That just dosent seem right almost all the 6 inch kits reccomend around a 35" tire.
Tire Size Caculator
Old Feb 26, 2006 | 07:32 PM
Tire Size Caculator
Your right I was thinking about the biggest tires for stock 285/75=31
Old Feb 26, 2006 | 07:39 PM
2k installed for the lift; tires around 300 a piece and wheels were some used ones we had lying around. We put this lift on an ugly truck that wouldnt sell on the lot, the thing sold before we even got it out of the shop, a girl bought it
We've got a 6" going on a black f250 with some 20's and 38" toyo mud tires that thing looks unbielevable.
I was never into lifted trucks until I started working here and saw what a nice lift and tire package can do for looks.
Old Mar 6, 2006 | 03:08 PM
getchusum99's Avatar
Actually 315/75 Are 35's , Most Manufactures Reccommend No Bigger Than 35's With The 6inch Lift, If You Plan On Going Offroading, Which I Hope U Are. That Way You Can Have A Lil Articulation Without Rubbing. But One Of My Freinds Have 37's On Stock Rims With A 6inch Fabtech Lift .if You Wanted To Save Some Money I Would Put The Lift On Yourself There All Pretty Simple And Easy With A Lil Mechanical Sense And Some Require Welding And Cutting Skills. I Definately Wouldnt Buy Anything From An Accessories Or 4x4 Shop They Rape You On Prices.
Old Mar 7, 2006 | 10:17 PM
joehawkz71's Avatar
yes a 315 75 is a 35" tire.......i put my lift in myself wit ha few buddies....it was prety easy to do....also some lift kits only recomend a 8" wide rim....but if you plan on using the fabtech lift you will be fine with a 10" wide or a 8" wide... also if you are gong ot be going with big tires you might want to think about get some different gears...
if you have just simple toolsyou could do a lift....if im not mistaken the only thing that you have to cut on the fabtech lift is some housing on the front diff....good luck!!
Old Mar 8, 2006 | 08:40 AM
Twotonefreak's Avatar
Depends on what gears your truck has? 3.42 or 3.73s? I myself plan on upgrading to 4.56s but I do a lot of towing during the summer. As for the wheel size, I'd go with the 18's if you can swing, they look so much better imo.
Old Mar 8, 2006 | 11:38 AM
joehawkz71's Avatar
yes go with the 18's if forgot to put that in my last reply.....i wish i would have went with the 18's on my truck instead of the 16's
