TOWING & OFFROAD PERFORMANCE Towing |Suspension | Wheels | Tires | Drivetrain |where the pavement ends.
How much do larger tires realistically affect performance
Old Oct 27, 2009 | 01:19 AM
RandomHero's Avatar
Default How much do larger tires realistically affect performance
I did a quick search without much luck. Lately I've been quite frustrated with babying my truck through the lovely streets of Oklahoma. Being that I can't own a stock truck I've been thinking of running the 7" pro-comp with some 305/70/16s.
With that said, how much should I expect the tires to hurt my times? Right now I'm running a 30" tall tire so it would be a 10% jump, but more importantly would be the weight difference.
If anything has anything to offer I would appreciate it.
Old Oct 27, 2009 | 07:28 AM
00ChevyScott's Avatar
Wearin' da big hat
David lifted his up for that same reason, and dropped it back down maybe a month later? Save yourself the trouble
Old Oct 27, 2009 | 08:37 AM
sharpshooter's Avatar
That is the size tire I run and yes it will affect your performance.You can see below my mods and how it runs.I ran a 12.9 in about 60* weather a few weeks ago.It is run at the track like you see it below.
Old Oct 27, 2009 | 11:28 AM
RandomHero's Avatar
I'm no good at guessing times, but what do you think you'd be at with a 30" tall tire or similar?
It gets old bottoming out all the time, and not being able to use the truck much.
Old Oct 27, 2009 | 11:35 AM
Phantom's Avatar
11 Second Club
Hasn't your truck already been lifted?
Old Oct 27, 2009 | 11:43 AM
Bumpers's Avatar
it does make a big difference... you also have to think about your truck being taller more windresistance and such. If you were to do anything i would say put it back around stock height and run a 31"-32" inch tire and and some more gear and it should be close to the same
Old Oct 27, 2009 | 11:44 AM
RandomHero's Avatar
Yes, but long before there was anything done to it performance wise. My truck is fun with the 150 shot, but it's not fun cringing every time I go over a bump or dip.
Old Oct 27, 2009 | 11:49 AM
BOSS302's Avatar
I say put it back to stock height with a 2" shackle in the back.
Old Oct 27, 2009 | 12:08 PM
RandomHero's Avatar
Yea, unfortunately I know I'll get bored with that. I guess you can't have your cake and eat it too.
Old Oct 27, 2009 | 12:26 PM
Phantom's Avatar
11 Second Club
Talking
Dodge 'em what is your drop? Could do it like tylers. His looks pretty badass. Cut a coil off the front springs and put hangers in the back
