TOWING & OFFROAD PERFORMANCE Towing |Suspension | Wheels | Tires | Drivetrain |where the pavement ends.
CST 4" Lift Pics
Old Apr 10, 2006 | 06:47 PM
NBred94's Avatar
Default CST 4" Lift Pics
I posted these in the GM general discussion forum, but thought I'd put them up here too. I know opinion is divided on 2wd lifts, but I'm real happy with it.
In the sunlight. It needs a bath...
Here's a before shot for comparison
Old Apr 10, 2006 | 07:01 PM
mwalls54's Avatar
Need More N2O Mod
Looks great
Old Apr 10, 2006 | 07:04 PM
NBred94's Avatar
Thanks, now all it (badly) needs is a set of 4.11's, and I'm good to go.
Old Apr 10, 2006 | 07:29 PM
stone150's Avatar
good job!! lifted 2wd's rock!
Old Apr 10, 2006 | 08:18 PM
endo's Avatar
Looks awesome! That is exactly how I want my truck to sit. Those are 285/70R17's right?
Edit and what size block do you have in back? Just a 2"?
Old Apr 10, 2006 | 08:45 PM
jephs422's Avatar
looks great, I wish I had the option for a small lift like that...
Old Apr 11, 2006 | 06:58 AM
NBred94's Avatar
Thanks. You are correct, these are 285/70/17 BFG's. I'm using a 3" block. I saw pictures of trucks with the recommended 2", and the rear looked to be a little low, so I went an inch higher, and am really happy with it.
Old Apr 11, 2006 | 03:36 PM
BiG A's Avatar
Looks good. What you pay for your lift?
Attached Thumbnails CST 4" Lift Pics-truck-006.jpg   CST 4" Lift Pics-truck-005.jpg   CST 4" Lift Pics-truck-004.jpg
Old Apr 11, 2006 | 04:29 PM
Nine Ball's Avatar
LS1Tech Co-Founder
Looks great. what sucks is that the other brand trucks start out that height from the factory, and GM makes them look like cars.
My 2WD was lifted 6" and had 33s on it, so lifted 2WD's don't bother me. I was able to drive thru several ditches and high flood waters without a problem, didn't need a 4x4 for my uses. Pics here: https://ls1tech.com/GMC.html
Old Apr 11, 2006 | 06:00 PM
NBred94's Avatar
The spindles were around $650, you can get Fabtech's or Rough Country's for cheaper, but they only give you 3" and won't clear the 285's without additional body lift, which I did not want to do.
GM 2wd's definitely start out low, but I'm about even with the HD 4wd's or a 1500 Z71 with the TB's cranked and keyed now. I had thought about going with the 7" long travel kit that CST makes, but I still need to fit into parking garages, and I'll be cutting it close in places as is.
I'm also feeling better with the extra 5.5" breathing room through the flash floods that happen here every couple of months. In stock form, my truck wasn't much better off than my wife's Infiniti.
gaps
Oct 15, 2015 02:53 PM
kalikid06
20
Oct 13, 2015 07:37 AM
reddfox
Sep 15, 2015 07:22 PM
Jake75
Sep 8, 2015 08:44 AM
the owl
Sep 4, 2015 04:09 PM
