TOWING & OFFROAD PERFORMANCE Towing |Suspension | Wheels | Tires | Drivetrain |where the pavement ends.
can i piece out a lift/ leveling kit?
Old Aug 4, 2010 | 07:25 AM
02whitelightning's Avatar
Originally Posted by Bumpers
alot of of kits like knuckle kits only drop the diff like 5" give or take and then you get your full 6" from cranking the torsion bars.... you could buy a kit like the rcx and not crank it and have your 4"maybe a tad higher and run 33s easy.
33s fit one a z71 stock though.
thats not a bad idea. i know they will fit, but i just want to be up higher, its not just about the bigger wider tires, i also want to pull up next to other trucks at a stop light and look down into their cabs. so maybe 6 inch would be good. is it possible to by the lift nuckle, and the torsion bracket? without a lift kit?
i also dont really wanna go that high, because im slowly working on my truck to give it some cojones, and bigger tires would mean id have to regear to actually be able to get some performance out of it.
Old Aug 4, 2010 | 10:44 AM
Bumpers's Avatar
you will have to buy the whole kit you cant just run knuckles and stuff... they are cheap enough might as well just buy it and you will want to go bigger later might as wells
Old Sep 7, 2010 | 03:29 PM
ok guys so after everything, i decided to go with 2 inch taller blocks and crank th t bars. no wi want a 2 inch body lift. any body know where i can get one?
Blue03sss
Mar 7, 2019 05:06 PM
silverstreak07
Jun 28, 2016 06:29 PM
WhoAteMySoup
Aug 20, 2015 09:52 AM
vmaxpro
Aug 4, 2015 07:02 AM
