TOWING & OFFROAD PERFORMANCE Towing |Suspension | Wheels | Tires | Drivetrain |where the pavement ends.
2wd to 4wd conversion?
Old Aug 13, 2006 | 10:41 PM
One_Slow4.8's Avatar
Default 2wd to 4wd conversion?
is it easy??? or is it just a waste of time??
Old Aug 14, 2006 | 05:32 AM
endo's Avatar
Everything I've ever heard about this is that it's a waste of time, unless you're converting the truck to a solid front axle (where it matters significantly less if you had 4wd to start with, as you're literally removing the entire drivetrain aft of the transmission as well as the entire front suspension regardless of whether you start with 4wd or not).
On a half-ton coil sprung 2wd, you'd need to replace the entire front suspension, modify the transmission, new rear driveshaft, different frame crossmembers (I think), buy a transfer case/front shaft/front diff and all the other front end goodies. It's always cheaper to just sell yours and buy a 4wd.
Old Aug 14, 2006 | 09:18 AM
thunder550's Avatar
High on diesel fumes
TurboBerserker had his AWD setup for sale
https://www.performancetrucks.net/fo...d.php?t=369828
Old Aug 14, 2006 | 12:20 PM
01-Z71's Avatar
Priced it for a friend because I work part time at advance auto and another friend runs an off road shop and it is way cheaper and easier to sell the 2wd and buy a 4wd!
Old Aug 14, 2006 | 12:40 PM
mwalls54's Avatar
Need More N2O Mod
this is a awsome deal but its constant awd and not 4hi/4lo. you would also need front arms/ torson bars/ and t bar crossmemeber.
Old Aug 14, 2006 | 02:31 PM
TravisH's Avatar
waste of time and money. It would be cheaper and more reliable to just buy a 4wd truck.
Old Aug 14, 2006 | 03:42 PM
ya thanks 4 the replies.. im just gonna keep my 2wd for now.. and try to sell it in 2 yrs or so... but thanks again..
Old Aug 15, 2006 | 06:20 AM
axisT6's Avatar
It all depends on how serious you are. I am doing a 1 Ton Straight Axle Conversion on my 95 2wd, and so far I am 6K into it. If you just plan to do some light offroading or something, I would lift the truck you have now, and put a locker out back.
In my case, I will taking the truck everywhere and will use the 1 Tons I am throwing underneath.
Of course, I could have bought a 4wd but, 88+ year model trucks have IFS which is absolute crap IMO, and 87- year model trucks don't have an easily tuneable EFI, and the frames are weaker.
But, like I mentioned, it all depends on how serious you are.
Pimpinpete
43
Dec 22, 2017 08:13 AM
Silver8ado
Sep 30, 2015 11:42 AM
Rockrz
Sep 29, 2015 09:07 AM
Blklgt
Sep 28, 2015 03:21 PM
sTNT971
Sep 26, 2015 04:22 PM
